Calculate Resistance from Z and Phase? - diyAudio
Old 8th December 2013, 05:02 PM   #1
kouiky is offline kouiky  United States
kouiky's Avatar
Default Calculate Resistance from Z and Phase?
My mind must be slipping today. If I have a known impedance with a known phase shift, what is the equation to calculate the parallel capacitance and find the resistance without that phase shift?
Example: 6 Ohms impedance, -30 degrees. I need to find that capacitance value and remove that to then find the resistance at zero shift.
Old 8th December 2013, 05:19 PM   #2
diyAudio Member RIP
At 30 degrees the real part is (cos) 0.866xZ R, imaginary is (sin) 0.5xZ.
rgds, sreten.
Old 8th December 2013, 05:42 PM   #3
kouiky's Avatar
Does this work for calculating the resistance component of a speaker driver when the Z and phase are known?
Old 8th December 2013, 08:01 PM   #4
Do you mean that you want to know the equivalent parallel resistance and equivalent parallel capacitance?
mag(Y)=1/mag(Z)
phi(Y)=-phi(Z)
G=mag(Y)*cos(phi(Y))
Rparallel=1/G
B=mag(Y)*sin(phi(Y))
Cparallel=B/(2*pi*f)
Hence, using cos(-x)=cos(x) and sin(-x)=-sin(x):
Rparallel=mag(Z)/cos(phi(Z))
Cparallel=-sin(phi(Z))/(mag(Z)*2*pi*f)
With mag(Z)=6 ohm, phi(Z)=-30 degrees:
Rparallel~=6.92820323 ohm
Cparallel unknown because the frequency is not specified. Examples:
f=1 Hz -> Cparallel~=13262.91192 uF
f=1 kHz -> Cparallel~=13.26291192 uF
2 phase DDS signal generator to run 2 phase AC sync motors Giordano Analogue Source 35 16th January 2015 05:25 PM
6550 plate resistance in triode mode? Calculate? Koektrommel Tubes / Valves 4 5th August 2013 12:43 AM
How to calculate mechanical resistance added by enclosure. SoulMagnet Subwoofers 0 10th January 2012 06:25 AM
Acoustic phase, electric phase,....phase ermes Multi-Way 6 27th November 2010 06:17 PM
calculate thermal resistance of alumimium heatsink bigpanda Everything Else 1 17th September 2008 09:14 AM
Copyright 1999-2017 diyAudio
