Issue with Marantz PM 66KI - diyAudio
Old 3rd December 2013, 10:28 AM   #1
Default Issue with Marantz PM 66KI
My Marantz PM66KI has been working totally fine until today
Hooked up a different pair of speakers (Missiom 760ise) and turned the amplifier on
All was working finem, turned the volume up a little more, then total silence, nothing.
Power light still on, remote works the volume control just fine
Switched off and back on again, however, the usual relay click (out of protection mode?) doesn't happen
Is it pure coincidence the amplifier expired when I got new speakers ?
Old 3rd December 2013, 12:24 PM   #2
dragonweed's Avatar
Yes, I've experienced similar mishaps when I worked as a service technician... Most likely what happens is that a different "new" speaker with different load and current demand on certain parts of the freq. spectrum put a stress on some parts, that were comfortable with your old speakers. If your protection relay does not "clicks" on, that usually indicates a fault in your output stage. Check your supply voltages, output DC level (before the relay), power transistors for shorts, driver transistors, emitter resistors, etc., most likely they are the culprit.
Old 3rd December 2013, 12:42 PM   #3
Thank you for the reply
My amplifier is going off for repair as anything above changing a plug or fuse is beyond me
I think the amplifier is far too good to consign to the bin, so hopefully a repair will be money well spent
Old 3rd December 2013, 01:21 PM   #4
Mooly's Avatar
I don't believe in coincidences
Make certain you have no strands of speaker wire shorting, either at the amp or speaker. Something to watch for again.
You would have to really abuse the amp to zap the output stage just by normal domestic listening... so its a bit strange what has happened.
Installing and using LTspice. From beginner to advanced.
Old 3rd December 2013, 01:25 PM   #5
The speaker cables use banana plugs all round, so that's unlikely to be a short caused by them, especially as I connected everything up when the amplifier was powered off
Old 3rd December 2013, 01:30 PM   #6
Mooly's Avatar
Very strange then...
If you have a meter then it has to be worth at least lifting the lid and seeing if it really has gone pop
Old 4th December 2013, 12:06 AM   #7
I'd put the ohm meter on the speakers. Maybe the speakers have a shorted voice coil...
The stuff you don't know always humbles us.........
Old 4th December 2013, 05:51 AM   #8
The guy who is repairing my amplifier is going to put a meter on my speakers at the same time, as it would be somewhat annoying to get the amplifier repaired and have the same thing happen as soon as I got home !
Thanks for all the replies
Marantz PM-94 StuartMoore Solid State 21 23rd February 2011 08:33 PM
Marantz PM 440 and PM 351 Schematic required Krokotam_ Solid State 0 22nd October 2008 07:36 AM
Marantz PM-11S1 Ipanema Solid State 2 31st July 2008 02:37 PM
marantz PM-66SE kinvig Solid State 2 2nd April 2008 11:46 PM
Marantz PM 94 Help brams Solid State 6 27th February 2006 06:23 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
