What do You think about this amp 3000w
Old 30th November 2013, 12:45 PM   #1
netiks is offline netiks  Azerbaijan
Default What do You think about this amp 3000w
Hello Everybody
What do You think about this amp?
Does anyone have schematics and pcb layout for this amp
It suposed to have 1500w on 8 ohms and 3000w on 4ohma mono
Output transistors NJW0302,NJW0281 but can work with 2SC5200,2SA1943
28 output transistors
Old 30th November 2013, 01:25 PM   #2
KatieandDad is offline KatieandDad  United Kingdom
KatieandDad's Avatar
What amp ???
Old 30th November 2013, 01:48 PM   #3
Default this amp
sorry for not uploading pictures first time
Old 30th November 2013, 02:54 PM   #4
Krisfr is offline Krisfr  United States
Krisfr's Avatar
Very interesting, more photos? Schematic? Specs?
Never give a Systems Analyst a screwdriver or hammer
Old 30th November 2013, 03:10 PM   #5
Michael Bean is offline Michael Bean  United States
Michael Bean's Avatar
Why do you need 3000 watts and where would you plug it in?
Mike
Old 30th November 2013, 03:26 PM   #6
Mike
Hi Mike I would probably plug it in the wall outlet and big speaker/speakers
If You think about power consumption Im from Europe so 240V power outlet 12 amps would be enough power but in the US 110 28amps to many amps draw
If You think thats too much power I installed 2x2000w rms amplifiers in my car
Im looking if anyone have pcb layout and schematics of this amp?
I saw it on Aliexpress but they ask 85$ FOR PCB only OUCH
Old 30th November 2013, 04:48 PM   #7
indianajo is offline indianajo  United States
indianajo's Avatar
There are watt ratings and there are other watt ratings. For one thing some car amps use 1 ohm speakers because the rail voltage is so low, 12 VDC. For speakers that make music that can sound like wooden instruments sometimes, the rating is more often 4 ohms or 8 ohms. Then there is the time the 3000 watts can be produced.
I'd like to see your 2000 w RMS car amp run into some resistors for acouple of hours and measure the heat sink temperature.
By contrast, PA amps from Peavey, Crown, QSC, will deliver the advertised watts, usually into 4 ohms, all night and tomorrow, too.
This amp has enough output pairs to be interesting, but without schematics or heat sink design, no opinion. The heatsink and fan design has a lot to do with long term power rating.
Dynakit ST70, ST120, PAS2,Hammond H182(2 ea),H112,A100,10-82TC,Peavey CS800S,1.3K, SP2-XT's, T-300 HF Proj's, Steinway console, Herald RA88a mixer, Wurlitzer 4500, 4300
Old 30th November 2013, 05:08 PM   #8
Default amp
this is one of my car amps 2000rms class D mono 1ohm stable
uploded picture
Yes I would like to see schematics and pcb layout too of that chinese amplifier with 28 output transistors i think it would run cool on 1500rms at 8 ohm it has ic ne5532
If anyone has Cirucit and pcb layout please upload
thanks
Old 30th November 2013, 05:19 PM   #9
Originally Posted by indianajo View Post
There are watt ratings and there are other watt ratings. For one thing some car amps use 1 ohm speakers because the rail voltage is so low, 12 VDC..
You are wrong car amps use SMPS power supply which can make from 12volts +/- 100volts
Half of the amp is SMPS and the other Half is amplifier see on the picture
Old 30th November 2013, 05:20 PM   #10
Vostro is offline Vostro  South Africa
Vostro's Avatar
I guess I understand what you saying indianajo, but the rail voltages in a car amp is Not 12V.
Many car amps are not rated in rms, but it's undeniable that good car amps are extremely powerful,
And many installations are so powerful that it's unhealthy to listen to them at full volume in the car.
What do You think about this amp 3000wHide this!Advertise here!
3000W speakers amplifier required cndu Solid State 5 1st May 2013 06:19 AM
3000w power amp sadaru Jonsen Solid State 9 27th December 2012 01:29 AM
PEAK PKC0AW 3000w 12vDC/110vAC Power inverter Dr Zeus Car Audio 2 14th February 2012 03:13 PM
100W up to 3000W amp for whitenoise Simy22 Car Audio 29 28th August 2004 05:40 PM
where are 1000W - 3000W subwoofer amps sold? pkgum Solid State 5 9th December 2001 06:48 AM
