Old 29th November 2013, 08:31 PM   #1
still4given's Avatar
Default Lowering the AC Votage to my speaker protetion circuit.
Hi Guys,
I am finishing up an amp build and had planned to install a speaker protection circuit. The circuit I have requires 12V-15Vac supply. The transformer I am using in the amp has a separate 16.5-0-16.5vac that I had planned to use for the speaker protection circuit. Is there a way to lower that to 15vac? I tried it as is and it over-heats the bridge in the SP circuit so to use it I will need to reduce the ac.
Thanks, Terry
Balanced X-BoSoZ, B1 Mezmerize, ESP P101, Symasym, KSA 50 X 2, Aleph X, Leach Low TIM, Leach Superamp, Honey Badger, VSSA X 4, (2-Jason, 1-PMI & 1-Peeceebee) DX Super A, DX MKIII, SKA GB150, JLH 1969, Fetzilla, Ovation Nx, TDA7294 Chip amp, JBL 4425, JBL 4412, JBL 4408, JBL 4312, Yamaha NX1000
Old 29th November 2013, 09:12 PM   #2
Andonio is offline Andonio  Italy
Originally Posted by still4given View Post
Hi Guys,
Thanks, Terry
you can use a rectifier bridge with 3 or 4 diodes for each side. (You should made it with discrete diodes). In such a way you can loose 1.8 to 2,4 volt for each side of the rectifier bridge.
Old 29th November 2013, 10:16 PM   #3
I don't think that will work. It needs 12 -15 vac. What you show gives DC.
Old 29th November 2013, 10:28 PM   #4
Just remove the capacitor and you get dc pulsating. Almost AC without the negative pulse.
Old 29th November 2013, 10:34 PM   #5
Not sure the SP will accept that.
Old 29th November 2013, 10:37 PM   #6
Can you post your SP schematic?
Old 29th November 2013, 10:37 PM   #7
You can feed your speaker protection circuit with DC (instead of AC) since you have in the protection circuit another bridge that can work also with DC input
Old 29th November 2013, 10:47 PM   #8
I will try feeding it with a 12v dc circuit and see if it accepts it.
Old 30th November 2013, 08:33 AM   #9
After a night's sleep, this morning I thought this possibility:
in this way you can power, with reduced AC, the speaker protection circuit
Old 30th November 2013, 12:51 PM   #10
Vostro is offline Vostro  Madagascar
Vostro's Avatar
maybe its easier to modify circuit, i.e place resistor in series with relay etc
Please help about AC motor circuit arnoldc Analogue Source 4 21st June 2009 02:37 AM
lowering AC heater voltage help? sbelyo Tubes / Valves 9 14th April 2008 01:28 AM
Input votage various rf sources peterlo Everything Else 4 25th June 2007 11:08 AM
high votage output stage latala Solid State 31 4th May 2006 12:18 PM
Can capacitors with different values and different votage Tony D. Solid State 5 5th October 2001 04:51 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
