Old 27th November 2013, 04:27 AM   #1
Default Transistors 101 question about 2 transistor Darlington configuration
I am slowly warming up to some design using transistors and am trying to understand the purpose of R1 in this figure of a Darlington pair:
Sometimes I see the Darlington pair drawn with R1 and sometimes not. Does the presence of this resistance change the performance of the Darlington or can it be omitted?
Old 27th November 2013, 07:39 AM   #2
mirlo is offline mirlo  United States
Without the resistor, the darlington gives a much higher current gain than the single transistor, but the transconductance of the composite is cut in half vs the single bjt and the high frequency performance is severely, almost fatally, compromised by a factor like the current gain of the second transistor.
This is because the transconductance and frequency response are both heavily dependent on collector current, which is much lower in the first transistor.
The resistor biases up the first transistor to speed it up and raise its transconductance.
( transconductance is the small signal ratio of ( delta I_c ) / ( delta V_be ). )
Eric
Old 27th November 2013, 04:25 PM   #3
So, if turn-off time is not critical, can the resistor be omitted?
Would the turn off response time show up in a SPICE sim of a circuit that uses the transistors? I could just check it that way...
Old 27th November 2013, 04:59 PM   #4
Mooly's Avatar
It depends entirely on the intended application but generally including a resistor is good practice. That said, some specific circuits would not use one but saying that I'm not thinking of audio applications. Try it in simulation, it certainly should show up because its a very real effect.
A simulation free zone. Design it, build it, test it.
Old 27th November 2013, 05:02 PM   #5
If this is a linear application there is no "turn-off"
If a switch (but why? who needs that gain in a switch?) then yes. Or maybe.
So, for linear, we do need an R, else the first transistor maybe operating at a very low Ic.
Like most engineering, its a compromise.
Old 27th November 2013, 05:25 PM   #6
Here is the application:
a Capacitance Multiplier with over-voltage protection
Look for the BD139/TIP3055 and BD140/TIP2955 in Darlington configuration.
Old 27th November 2013, 06:18 PM   #7
Mooly's Avatar
I probably would add something like a 1k in that application. Another practical issue could be the rating of the BD139/140 and the maximum allowable collector current. Something like TIP41C/42C might be more appropriate.
Old 27th November 2013, 07:01 PM   #8
Although I didn't post an updated schematic I changed the driving (first) transistor from BD139/BD140 to 2N4401/2N4403 and am using TIP35C/TIP36C as the second (power) transistor.
In my sims I see the first transistor current not exceeding a few tens of milliamps peak. I happen to have the 2N devices on hand and they are rated to 600mA. The BD139/BD140 were overkill. Vin and Vout are always within a few volts of each other, unlike in a power amp.
Regarding turn off time, the fastest transient that the transistor will be dealing with is 120Hz ripple - nothing very fast at all. I don't see any effect whether the resistor is in the circuit or omitted. I was using a value of 220R-470R.
Old 27th November 2013, 07:16 PM   #9
You are confusing signal rise/fall time with turn-off time, I think.
Turn off time, roughly, is how the transistor comes out of its switched on state (ie saturated) to a linear or switched off (no base current ) state.
This is NOT a switching application - the transistors are on all the time after initial switch on.
Linear parameters apply, not switching.
Old 27th November 2013, 07:23 PM   #10
Mooly's Avatar
You have to look at the collector current of the drivers under load. With all those paralled devices I assume it a supply of high current output. Try a pulsed load on the output (simulate it) using a FET and load resistor. You could easily need several hundred milliamps or more to drive those output devices. The 2N devices are nowhere near suitable.
Darlington output transistor hunting.. gmarsh Solid State 16 30th January 2013 05:12 PM
Darlington transistors carlmart Parts 0 26th May 2011 12:36 AM
Can I build up these Darlington transistor if I use two BJT transistor ? gaborbela Parts 9 15th July 2010 06:30 PM
darlington transistor LTspice model ? flacer Solid State 6 21st May 2009 12:36 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
