Calculatin VAS gain with CCS
Old 26th November 2013, 01:18 PM   #1
Boscoe is offline Boscoe  United Kingdom
Default Calculatin VAS gain with CCS
So if we have a regular vas stage with one gain transistor loaded a constant current source how is the voltage gain of the stage calculated?
Boscoe
Audio projects and more: gswdh.co.uk
Old 26th November 2013, 01:57 PM   #2
richie00boy is offline richie00boy  United Kingdom
Did it Himself
richie00boy's Avatar
Well the gain of a common emitter output stage is basically Rc/Re. You need to know the effective impedance of the CCS then it's an easy sum. If you have no physical emitter resistor then it comes down to the value of the intrinsic "little Re" as our lecturer used to call it, of the BJT.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, modules and more.
Old 26th November 2013, 02:10 PM   #3
sajti is offline sajti  Hungary
Boscoe
That is almost impossible, if the load is only the output EF. So the gain depended by the input impedance of the EF, divided by the total emitter resistance. But the input impedance is depended by the load, the output current, the temperature. So it's not easy to predict.
You apply fixed resistors from the VAS output to the ground, and if this resistor is small enough (1/10 of the worst case input impedance of the output EF) it will depend the gain.
Sajti
Calculatin VAS gain with CCSHide this!Advertise here!
Depletion MOSFET as gain device (not CCS) ? pixpop Solid State 6 27th February 2012 05:17 PM
A superior VAS clamp and VAS current limit for the Blameless. GK Solid State 128 19th October 2011 04:03 PM
low VAS sealed better than high VAS? matos81 Subwoofers 3 7th April 2006 12:28 PM
heretical unity gain and ccs question selfwilly Tubes / Valves 14 28th March 2006 03:54 PM
CCS Conceptual Qs, Using Gary Pimm CCS as Example DrDeville Tubes / Valves 20 12th May 2004 03:41 PM
