Need an all NPN (Quasi) ops power amp - Page 2 - diyAudio
Old 23rd December 2003, 08:50 AM   #11
Alfetta87's Avatar
Originally posted by JojoD818
Alfetta87,
Got the pdf, thanks! It's sad I can't read German but I think I can follow through. In the schematics, there are parts that are encircled using a pencil, protection circuit maybe, I wonder why?
Have you tried this amp?
Best Regards,
JojoD
JojoD,
If you have questions, ask me. I don't know why some parts are encircled, but to me it looks as if there isn't a protection circuit; but rather the inversion circuit (somebody corrects me if I'm wrong).
I use to build this amplifier (in a very earlier version, more than 25 years ago), with a slightly higher power version - thus not very reliable because of the missing power protection (use a fuse in the output, helps a little). Don't askme the sound, my speakers at that time were equipped with a piezo tweeter, some radio shack midranges and with an a three way universal crossover...
Note that years ago, the NAD 3020 was using the 2N3055, but in push pull (with a MJ2955 as a complementary).
Try it and let us know.
Rgds,
- dan
It is worth to keep your mouth shut and let people think you’re stupid; rather than to open it and thus eliminate any doubts...
Old 23rd December 2003, 09:00 AM   #12
JojoD818's Avatar
Dave,
Thanks so much for the link.
Alfetta87,
Sound is not much of an issue since it would be used for a school project and most importantly for learning purposes.
I presume that the P3A amp can be outfitted to become a quasi comp ops right?
JojoD
Old 23rd December 2003, 09:10 AM   #13
Alfetta87's Avatar
JojoD
I didn't get your question???
P3A? comp pos?
Sorry, it's too early for me (oops, 10AM...)
- dan
Old 23rd December 2003, 11:32 AM   #14
JojoD818's Avatar
Alfetta87,
I know what you mean, I just got up too.
What I mean was the P3A has a CF output topology, can it be modified into a quasi complementary output topology? Since I already have a P3A board to tinker with.
JojoD
Old 23rd December 2003, 12:08 PM   #15
Alfetta87's Avatar
I do not know the P3A, but the proposed schematic from Elektor is actually a quasi complementary ouputstage.
- dan
Old 23rd December 2003, 03:59 PM   #16
JojoD818's Avatar
Alfetta87,
I will study the amp from Elektor first and will try to build it since you have already built it before. This should be a good source of ideas.
Thanks!
JojoD
Old 24th December 2003, 12:10 AM   #17
X.G. is offline X.G.  China
X.G.'s Avatar
Hi,jojoD.
I would advice you to try one of the amp series designed by Kaneta which is Japanese DIY expert.Their performances were claimed better than the complimentary amp.
The circuit is 'compeletly complimentary' which named by the designer.I remember that those trans of the simplifier BJT amp are:2 pcs of 2sk30ATM(FET),2sc959/2sa606, 2n3055 and
1 pc of 2N5465(FET).
I had tried the simplifier one,and found that its performance is good even better than the ordinary complimentary amp.The each channel trans of mine are 2sk30(3 pcs),2sd669/2sb649(2 pcs each),2sd600(2 pcs)
regards
X.G.
Old 25th December 2003, 01:47 PM   #18
X.G.'s Avatar
Sorry for my mistake.Corret it now:
The circuit is 'compeletly symmetrical' which named by the designer (Kaneta).
Old 25th December 2003, 04:04 PM   #19
Easyamp's Avatar
You could use national's lm3875 as a possible model to build off of, I never have so Thats about all I can say.
Cheers
Single supply quasi complementary mosfet power amp slideman82 Solid State 8 7th March 2009 01:25 AM
(Quasi)complementary JFET power amplfier R-K Rønningstad Pass Labs 21 15th July 2007 07:21 PM
High power regulated, quasi-comp. Stocker Solid State 26 28th December 2004 05:13 AM
Copyright ©1999-2017 diyAudio
