TGM8 - my best amplifier, incredible bass, clear highs, no fatigue (inspired by Rod Elliot P3a)
Should Q3 have small heat sink? The dissipation is around ~350mW.
Bimo, the next PCB revision will place the VAS in a better position to attach a sizeable heatsink made from aluminium flashing. With 10mA it will get pretty warm on 35V rails and with 42V it will get quite hot indeed.
Bigun, what are your thoughts on substituting a KSA992 for the input transistor? Would the extra gain be beneficial? Would I need to recalculate the compensation?
I tried to build this in Ltspice but realized I don't have any models for the MOSFETs. Is there a place to get those?
Try these:
.MODEL 2SK1058_D NMOS (VTO=403.969M KP=20U L=2U W=29.7482M GAMMA=0 PHI=600M LAMBDA=184.988F RD=60.8251M CBD=2.56138N IS=10F CGSO=1.13517N CGDO=1.13517N TOX=0 NSUB=0 TPG=1 UO=600 RG=50 RDS=1MEG )
.MODEL 2SJ162_D PMOS (VTO=842.193M KP=20U L=2U W=21.3317M GAMMA=0 PHI=600M LAMBDA=20.7067M RD=837.199M CBD=2.96862N IS=10F CGSO=1.13517N CGDO=1.13517N TOX=0 NSUB=0 TPG=1 UO=600 RG=50 RDS=1MEG )
Try these:
Thanks bimo,
I am having trouble getting the pots to work. Maybe one of you can help me with that.
Terry, thanks for putting the time into this. I'm not familiar with Spice and your contribution is invaluable.
My schematic doesn't have any source resistors on the outputs as you've already noticed. One way to set the bias is to temporarily install some 10R /5W resistors on the power rails and measure the Vdrop across those.
- Set the rails to +/- 35 to 45V
- In your Spice model set R13 and VR1 to 0R
- Measure and take note of the Vdrop across one of the 10R power resistors
- increase VR1 until the Vdrop increases by 1V.
- this 1Vdrop should equate to ~100mA bias
Hi Christian,
As you can see, I have a long way to go using Ltspice. The more I use it, the more I learn. I almost always have to get help from someone to get it working properly. It has been very valuable to me for trouble shooting. If you have a working model in spice, you can take measurements at different points in the model and compare it to your non-functioning board and often find the issue. At least it gives you a baseline to work from. A very nice, free tool. I highly recommend you DL it and start practicing.
Blessings, Terry
Terry, it high up on my "to do" list. Unfortunately it is a fairly steep learning curve and I haven't had the time to focus on it lately.
I'm hoping that Bimo, yourself and other knowlegeable lurkers watching this thread, who are familiar with this tool may be able to assist this time around.
Hi Christian,
My pleasure to do the part I know. Another nice thing about spice is that it won't let you name an NPN with a PNP name. On your schematic, Q3 is a P channel transistor but you have it labeled KSC3503. That is an n-channel transistor. When I went looking for it in spice it only showed me the p-channel devices. They are KSA. Fun stuff!
