Negative feedback?
Negative feedback?
Old 6th November 2013, 01:13 AM   #1
Tacbob is offline Tacbob
Default Negative feedback?
I'm trying to learn a little about amplifiers and had a couple of questions about negative feedback. They might seem a bit simplistiic to most of you but anyway...when a speaker is connected to the output of an amplifier, is it in the feedback loop? I understand that speaker damping is a property of the amount of negative feedback so is the speaker is in the loop? What about things like the output zobel or a coupling cap?
Thanks for your time!
Old 6th November 2013, 01:36 AM   #2
Fast Eddie D is offline Fast Eddie D  United States
With the exception of motional feedback designs or back emf from the loudspeaker, no.
No.
coupling cap
Usually not.
Old 6th November 2013, 01:19 PM   #3
The NFB "loop" is from the output tapping point to the input injection point.
That loop is usually inside the amplifier.
All the other bits both before and after the amplifier are outside the loop.
regards Andrew T.
Negative feedback?Hide this!Advertise here!
How the negative feedback really works and an alternative feedback question Amit_112dB Solid State 37 21st April 2014 04:16 PM
negative feedback dscottguitars Instruments and Amps 7 13th September 2011 05:43 PM
Negative Feedback? Binaural Tubes / Valves 15 12th March 2009 08:05 PM
Negative Feedback AmpBuilder225 Tubes / Valves 7 20th February 2009 09:05 PM
Get away from negative feedback ? N-Well Pass Labs 3 1st March 2006 11:17 PM
