Has anyone found/used fast recovery full bridge rectifiers in the 400V, 35A range?
#2 |
Account Disabled
why do you have to have a fast recovery bridge?
#3 |
Look at: http://www.edidiodes.com/pdf/Bridges/xPIR.pdf
also www.diodes.com, a pair of MURB161OCT configured into a bridge might work for you. Or a a pair of Schottky rectifier assemblies SBG3030CT. Spice models are available so you could "try before you buy". |
#4 |
Account Disabled
sam, how do you configure one pair of those CT type rectifiers into a bridge? I thought it was impossible.
#5 |
Millwood, The answer is you can't. All this Christmas eggnog has addled my brain. Diodes Inc only has common cathode configurations. You would need to match one of those with a common anode configuration. I have seen datasheets from someone else where you can order them that way by changing a suffix. Anyway, just buying a super/ultra fasr bridge would be easier. Edidiodes does have those.
The REAL problem is finding a distributor that stocks any of them, or talking the manufacturer out of samples. Of course, it may all depend on what the original poster wants one for. Unless it is something very, very special I'd bet you can get what you are looking for just by snubbing them. The definitive dyi article on that seems to be the one a www.hagtech.com. |
#6 | |
Electrons are yellow and more is better!
/Per-Anders (my first name) or P-A as my friends call me |
#7 |
Im gonna try making a schottky bridge rectifier by paralelling the units and using 4, mount the whole thing on a copper plate and cast them in heat conductive epoxy...should be a good solution and easy to mount/ replace in case of failure, since its one unit.
Magura
Everything is possible....to do the impossible just takes a little while longer. www.class-a-labs.com |
#8 | |
Account Disabled
thanks, Sam9 for the clarification. I am quite surprised why companies make those common cathode diode "modules" given that most of those modules are used in SmPS. only if they also make matching common anode modules, |
#9 |
Anyone used the RURG8060 by fairchild?
80Amp 600PIV ratings discrete diodes. Fast and soft recovery. 800Amp peaks. I want to use these for a 800watt per channle amp? ideas? |
#10 |
I was just curious, the full bridge makes connections easier. They will be used on the secondary of the power transformer so schottky's don't have the voltage I need.
I did find one supplier but I know nothing about them. http://www.diotec-usa.com/GUIDE3.html |
| byw 100-200 in fast bridge rectifiers | janusz | Solid State | 2 | 8th August 2006 01:08 AM |
| fast vs. slow rectifiers | Franz | Pass Labs | 31 | 17th October 2005 11:55 AM |
| FS: IXYS Ultra fast bridge rectifiers | dqswim | Swap Meet | 19 | 7th July 2004 05:43 AM |
| 200V 50A Fast Recovery POWER Rectifiers | kilowattski | Pass Labs | 7 | 17th February 2004 04:15 PM |
| fast vs. slow rectifiers for leach amp | janey | Solid State | 5 | 2nd January 2003 08:25 PM |
| Page generated in 0.10768 seconds (77.95% PHP - 22.05% MySQL) with 10 queries |
