Dx Juan layouts ideas PCB - Page 9 - diyAudio
Old 6th November 2013, 04:59 PM   #81
Rudi_Ratlos's Avatar
So, Juan: you are able to draw "rounded" PCB-tracks?!
Never mind - find attached a very simple "Soft- Power-On - PCB", which can be used by 115VAC primary DIYers and 230VAC primary DIYers as well.
http://abload.de/img/topviewxroh7.png
Best regards - Rudi_Ratlos
P.S.: This layout has been done with the EAGLE-educational software, since it is < than 100x100mm.
Old 6th November 2013, 05:17 PM   #82
vargasmongo3435's Avatar
Send a message via Yahoo to vargasmongo3435
Yes Rudi jejejejeje I'm trying different styles of PCB layouts styles there are many way to do things and I'm trying to polished myself a bit more
can I use that for any amplifier project ? it will be nice to turn on a amplifier with out using a toggle switch sound "clack"
Juan
audio fanatic only
Last edited by vargasmongo3435; 6th November 2013 at 05:23 PM. Reason: can not upload image ?
Old 9th November 2013, 03:14 AM   #83
Concept from Willie extended
best regards
Juan
audio fanatic only
Old 9th November 2013, 05:52 PM   #84
Concept from Willie extended 2
Willie I'm using your reference to see if I can make a good one I still not sure if I want the coil on the board maybe I will place it away from the circuit , also I want to keep tracks no so short nor to long is way too difficult any way this is just practice .
moderators can you remove post #83 when you get a chance please
image upload fail this is the image that fail that day.
Juan
audio fanatic only
Old 9th November 2013, 06:02 PM   #85
wiljj78 is offline wiljj78  Philippines
wiljj78's Avatar
Mister moderators can you remove post #83 when you get a chance image upload fail this is the image that fail that day.
Juan
Look very nice bro... Have fun!
Old 9th November 2013, 06:12 PM   #86
thanks man
best regards
Juan
audio fanatic only
Old 10th November 2013, 07:55 PM   #87
Well today I'm almost done with the layout basically is mister Miles AX-14 with mister Willie reference it came out a little weird looking I have to try again anyway this is for fun thanks Willie
do not mind about possible errors I still checking the layout
best regards
Juan
audio fanatic only
Old 16th November 2013, 10:52 AM   #88
Ok here is the AX-11 BETA board I'm not sure about living the coil on the board maybe I will make a separate circuit to avoid having the nasty magnetic fields away from the circuit but I guess since this will not generate so much the AX-11 is rated at 100W I will not run the amp to the clipping jejejejeje well this is one I have more versions to make also B500 from mister Miles Apex
"yes I know I'm coping the already made layouts but that is the best way to learn jejejejeje" here is B500 but I'm not sure if leave it in that "top mount style transistor installation way"
also here is wow I don't know what happen here AX-14 uhmmm not sure about this one
This is just concept ideas not really test it, only for "figure out styles reference"
the B500 and PA protect AX-14, AX-11 layouts belongs to mister Miles Apex.
best regards
Juan
audio fanatic only
Old 12th May 2014, 01:03 PM   #89
Has some seen this layout ?
finally I got it I always want it to make a clone of this one 1995 Elektor
Juan
audio fanatic only
Old 12th May 2014, 01:16 PM   #90
meanman1964's Avatar
Juan,you realy knows how to use Sprintlayout
ELEKTOR - Schematics and PCB layouts dudaindc Elektor 17 19th December 2016 04:42 AM
Gainclone, dhr turbp pcb, dx blam es pcb all for sale joka22 Swap Meet 3 14th July 2010 11:18 PM
dhr and dx ampilifer pcb available joka22 Swap Meet 1 7th July 2010 10:17 PM
Juan Diego Florez -- in a WOW Rossini recording jackinnj Music 0 11th October 2006 02:06 AM
post your business end PCB layouts! jwagnerhki Class D 6 24th July 2006 07:56 PM
Copyright 1999-2017 diyAudio
