VSSA Through-Hole-PCB build thread
Old 29th October 2013, 12:08 AM   #21
metallicus69 is offline metallicus69  Netherlands
I am interested in 1-2 pairs of boards for sure.
And I am interested in the 4OHM discussion as well
Cheers!
Old 29th October 2013, 12:57 AM   #22
PMI is offline PMI  United States
Cheers!
I added your name to the list. Perhaps the question in regard to 4-ohm speakers should be, how much power does it make sense to design for?
I have been thinking of this as a "small" amp. Sort-of like a sports car. You avoid some of the pitfalls of bigger heavier vehicles, precisely because it is small, so good performance does not cost much.
The most obvious answer to more power without changing the design much is to use the ALF16N/P devices, but it will no longer be low cost.
Old 29th October 2013, 12:59 AM   #23
didiet78 is offline didiet78  Indonesia
Originally Posted by JOHN BALI View Post
Yes the component selection is good start...
1. I see some other CFA-amp use 2-3watt feedback resistor
see NX-amp by Bonsai
now where I can find these dale resistor
so 0.5watt is minimum if we go for higher supply (this what I thought).
-snip
Hallo bli John, on F5 (i think it CFA too) use 4 x 3 watt resistor.
I think it depend on current passing through on the resistor not depend on voltage, hence it call CFA. CMIIW
PMI, any schematic ?
Didiet
Old 29th October 2013, 01:01 AM   #24
Still reviewing it.
Old 29th October 2013, 02:22 AM   #25
still4given is offline still4given  United States
still4given's Avatar
I've been playig my TO-3 VSSA on 4 ohm and 37V rails for a few days now without any issue that I can see. What should I be looking for to know if there is a problem?
Thanks, Terry
Old 29th October 2013, 03:04 AM   #26
Thanks, Terry
Those are Jason's boards, so I would ask him, but if there was a problem, you would probably know it by now.
Old 29th October 2013, 03:16 AM   #27
jkuetemann is offline jkuetemann  Canada
jkuetemann's Avatar
Thanks, Terry
The magic blue smoke would be set free if there were an issue. The MOSFETs are really quite forgiving and rugged, given the dynamic nature of music I would not expect any issues with your set-up. For testing with full power sines use 8 ohm.
---Jason Kuetemann---
Power is only granted to those willing to lower themselves enough to pick it up.
Old 29th October 2013, 04:27 AM   #28
It's not even breaking a sweat. This is a very impressive amp. I just built a speaker switch so I could do an easy blind test with my amps. I have to tell you, the peeceebee doesn't take a back seat to any of my amps. I am using a B1 mezemerize and an X-BoZoZ for volume controls. I have been amazed how close all the amps are when their volumes are equalized. To my surprise, the peeceebee has a bigger soundstage than my Honey Badger. It really is an amazing design.
Old 29th October 2013, 06:27 AM   #29
meanman1964 is online now meanman1964  Belgium
meanman1964's Avatar
Originally Posted by PMI View Post
30~35V into 4 ohms, if you want to stay safe, but you could push it quite a bit, if you wanted to. With care, you can make some assumptions about the average current, and calculate back from that. most people want the extra power for dynamic range, not to blast out a continuous 1KHz sine wave at maximum power (chuckle).
edit:
I am planning on making a couple small board orders, and for now I am just keeping a list of interested people.
Two boards for me too
Old 29th October 2013, 07:44 AM   #30
ivanlukic is offline ivanlukic  Serbia
Two pcbs for me!
VSSA Through-Hole-PCB build threadHide this!Advertise here!
PCB Through Hole Repair crazifunguy Parts 6 19th October 2011 03:54 AM
Looking for through-hole PCM2704 DIY PCB tommy_o Parts 2 2nd June 2011 02:56 PM
Making plated through-hole PCB rozon Parts 2 1st May 2009 02:57 AM
PCB Hole Size ptah Parts 10 30th November 2006 02:51 AM
How to remove thru-hole IC from multi-layer PCB? Alexandre Parts 20 21st February 2006 10:32 AM
