diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Solid State (http://www.diyaudio.com/forums/solid-state/)
-   -   Diamond Differential Amplifier (http://www.diyaudio.com/forums/solid-state/244892-diamond-differential-amplifier.html)
apexaudio 27th October 2013 11:01 PM
2 Attachment(s)
Idea for full symmetrical amplifier...
moschfet 27th October 2013 11:16 PM
Wrong schematic? ;)
Mark Johnson 27th October 2013 11:29 PM
1 Attachment(s)
The "bias spreader" circuit is not fully symmetrical. I have attached a figure from US Patent 3,995,228, issued 30 Nov 1976 to Nelson S. Pass of Threshold Corporation. It shows a bias spreader circuit which IS fully symmetrical.
apexaudio 27th October 2013 11:51 PM
Originally Posted by moschfet (http://www.diyaudio.com/forums/solid-state/244892-diamond-differential-amplifier-post3682145.html#post3682145)
Wrong schematic? ;)
This is not final schematic, if you find some mistakes...
moschfet 28th October 2013 12:04 AM
Originally Posted by apexaudio (http://www.diyaudio.com/forums/solid-state/244892-diamond-differential-amplifier-post3682185.html#post3682185)
No, but this is not a Diamond circuit.
apexaudio 28th October 2013 12:23 AM
Originally Posted by transistormarkj (http://www.diyaudio.com/forums/solid-state/244892-diamond-differential-amplifier-post3682162.html#post3682162)
I will use symmetrical bias circuit in final schematic.
borys 28th October 2013 12:47 AM
3 Attachment(s)
Maybe You can use similar topology as krell ksa 100.
Few examples bellow + diamond amp I have made recently.
For two first stages maybe it would be handy to use ccs instad of zeners supplies ?
Or idea nr 2:
-j-fet differential amps (I have used them even in ax11/sansui amp with no changes in circuit)
-bjt differential amps
-Vas
-driver
-output stage
One question, why 4 differential amps ? Two amps (as ksa100) + predriver+vas+driver+output stage should be good too.
PMI 28th October 2013 01:03 AM
Originally Posted by borys (http://www.diyaudio.com/forums/solid-state/244892-diamond-differential-amplifier-post3682237.html#post3682237)
Few examples bellow + diamond amp I have made recently...
BG3 looks like a very cool design, at least from the schematic, :up::)
OnAudio 28th October 2013 07:27 AM
Thank you Apex for all you do for audio. Thanks for posting. Just a few quick ones
Are you using +-45V rails ? . I suppose diamond stands for in house name of this amplifier :) ?
kind regards,
Harrison.
aparatusonitus 28th October 2013 08:57 AM
Originally Posted by moschfet (http://www.diyaudio.com/forums/solid-state/244892-diamond-differential-amplifier-post3682199.html#post3682199)
You are right...it's Diamond Differential circuit (Sansui), as in the title.;)
Resources saved on this page: MySQL 18.75%
