oscillation in passive buffered preamp
Old 20th December 2003, 05:05 PM   #11
buchignani is offline buchignani  Canada
Default Probably not oscillating
If you have used the stacked BUF634 in high bandwidth mode they are going to throw out a lot of heat even when not driven. Three stacked ones in high bandwidth mode will run 45 mA undriven. See p. 5 of the info sheet.
There's no functional need to run in full bandwidth mode. A 300 ohm resistor for each BUF634 will give you 3 x 7mA and still good bandwidth. Norman
Old 20th December 2003, 07:24 PM   #12
Jocko Homo is offline Jocko Homo  United States
Banned
Default What's wrong with this picture....
"Passive Buffered"? How the hell did you determine that? It is either one or the other.
Stacked buffers?.....physically?......yep....Phred has it right.
If you can't drive your application with only one of these, you are in for problems.
Jocko
Old 22nd December 2003, 07:34 AM   #13
Flemming J P is offline Flemming J P
Send a message via MSN to Flemming J P
I didn't come up with that name. It is a copy of http://www.stereophile.com/amplificationreviews/54/
I skiped one buf634, so I could fit input and putput resistors to the 2 that was left.
The guys at headwize stacks buffers, ok they drive headphones and not amps, but I thought why not try when I have them around anyway.
Old 22nd December 2003, 04:42 PM   #14
Banned
JP.......send me an e-mail, if you get the chance.
Jocko
oscillation in passive buffered preampHide this!Advertise here!
Buffered Passive I/V vs. Active I/V VEC7OR Analog Line Level 3 23rd September 2007 12:38 AM
passive buffered line drive plans wanted! shaun5 Chip Amps 0 11th December 2005 09:40 PM
Nuuk Buffered Passive Preamp Issue filholder Chip Amps 51 22nd November 2005 09:00 PM
Struggling with my buffered GC preamp Russ White Chip Amps 3 26th March 2005 08:12 AM
Buffered Passive Preamp Freddie Solid State 22 30th June 2003 09:05 PM
