60W simple Audio amplifier with TL071
Old 22nd October 2013, 02:33 AM   #1
Gost22 is offline Gost22  Bolivia
Banned
Question 60W simple Audio amplifier with TL071
Hello guys!
I came across this circuit amplifier, so I wonder if this circuit will work well without oscillations?
What kind of sound quality to give so.
They gave some possible changes to the schematic in order to improve?
What operating amplifier (OPA-IC1), LF351, NE5534N or TL071 here would be most suited to the this amplifier??
Is may include the inclusion of the speaker output impedance of 4R?
Anybody can do a simulation of this circuit.
Thanks for your help and suggestions!
Old 22nd October 2013, 06:50 AM   #2
djk is offline djk
R.I.P
djk's Avatar
Will latch up to the rail until you add a resistor from pin 3 to ground, try 47K.
Need an output Zobel, 10Ω+0.1F should do.
Choose a better opamp, the old bi-fet's will latch to the negative rail when you drive the amp hard.
There needs to be some small resistors in series with the diodes, there is not enough bias.
Bias pot won't work as drawn, will only reduce it further into class B.
Needs frequency compensation in the feedback loop.
I would add 1nF caps in parallel with R17 and R14.
I would change R18 and R13 to 4.7Ω
May need 47Ω in the base of Q1 and Q2.
Change the collector resistors to 0.22Ω, and add another 0.22Ω pair in the actual emitter circuit.
Candidates for the Darwin Award should not read this author.
Old 22nd October 2013, 03:55 PM   #3
Banned
Thumbs up Changes in the sematic
Mr djk, thanks for are suggestions for some changes in the sematic!
Guys go on,....
Old 22nd October 2013, 04:21 PM   #4
R.I.P.
Search on "Puccini", "Brio" and "Texan" amplifiers.
All use standard audio op-amps for the 1st stage.
rgds, sreten.
Old 22nd October 2013, 04:28 PM   #5
Banned
Lightbulb Puccini audio schematic
rgds, sreten.
Hi sreten!
Give some website of these
Think of this schemtic!?
Old 22nd October 2013, 04:36 PM   #6
R.I.P.
Originally Posted by Gost22 View Post
Hi sreten!
Give some websiteof these
You've got a problem using Google ?
rgds, sreten.
Old 22nd October 2013, 04:39 PM   #7
Banned
rgds, sreten.
Yes for yahoo!?
Old 22nd October 2013, 06:31 PM   #8
rafsky is offline rafsky  Italy
Send a message via MSN to rafsky
rgds, sreten.
The Puccini very old series use operational amplifier like NE5534, the new are fully discrete
60W simple Audio amplifier with TL071Hide this!Advertise here!
SIMPLE BUT EFICIENT AUDIO AMPLIFIER ! Radu1984 Solid State 7 19th September 2011 07:14 AM
6N11+TDA7293 60W+60W Amplifiers fn9mm Chip Amps 5 28th August 2011 12:37 PM
Kuroda TL071 60W FET Amp (1982) steph_tsf Solid State 18 28th August 2011 12:34 PM
Non Bootstraped amplifier 60W IrishboyM4 Solid State 14 23rd April 2007 10:53 PM
60w in 8 ohms ESP amplifier... Lisandro_P Solid State 15 19th April 2001 05:20 PM
