Single or Dual opamp package?
Old 18th December 2003, 03:47 PM   #1
JojoD818 is offline JojoD818  Philippines
JojoD818's Avatar
Default Single or Dual opamp package?
This may sound stupid but I really can't let it go and I need your opinions.
Let's say I want to build a buffer for my gainclone, leach amp, or whatever amp that I have that has 2 channels (stereo). Would it make a difference if I use 2 single package opamps or just 1 dual opamp provided that my buffer only needs 1 opamp per channel.
I hope this makes sense.
JojoD
Old 18th December 2003, 04:03 PM   #2
PMA is offline PMA  Europe
PMA's Avatar
For the highest requirements (crosstalk etc.) use single chips.
Old 18th December 2003, 04:34 PM   #3
Pedja is offline Pedja  Serbia
Though they have some shortcomings (for instance you canít use separate supplies), dual opamps give that interesting possibility for better layout of the feedback loop - practically always their output and inverting input are neighbor pins. This might be important.
Pedja
Old 18th December 2003, 05:21 PM   #4
cadmaniac is offline cadmaniac  United States
I found that using some singles helped with my PCB layout (4-way active LR2 crossover). Being new at this; I didn't want to crowd it much. I also used some physically larger-than-typical caps, so double opamps would've meant more longer traces.
Old 18th December 2003, 05:38 PM   #5
millwood is offline millwood  United States
Account Disabled
most of dual opamps are fabricated completely separately, and some of them specifically say so in the datesheet. so it would surprise me if you can hear a difference between dual vs. 2x single.
Old 18th December 2003, 05:44 PM   #6
dhaen is offline dhaen  Europe
diyAudio Moderator Emeritus
dhaen's Avatar
That may well be true, but the heat from one half affects the other. If you're using a dual, don't use each half for different applications.
Old 18th December 2003, 08:04 PM   #7
purplepeople is offline purplepeople  Canada
purplepeople's Avatar
What do you mean different applications?
1) Opamp A for left channel and opamp B for right channel.
2) Opamp A is buffer for opamp B in high gain.
3) Other configurations?
:)ensen.
Those who claim to be making history are often the same ones repeating it.
Old 18th December 2003, 10:27 PM   #8
dhaen's Avatar
Jensen,
I was talking abour using different drive currents from each section, so (3).
So let's say use them for the same mean signal level, and with same load.
Old 18th December 2003, 10:46 PM   #9
Geoff is offline Geoff  United Kingdom
It may well be the case that the two op-amps are separately fabricated, but they share common supply rail connections so one op-amp will modulate the other unless they are carrying identical signals.
It is surely far better to use single op-amps where the individual supply connections can be suitably decoupled and isolated so that cross-modulation cannot occur.
Old 18th December 2003, 10:49 PM   #10
Account Disabled
even if you use singles, they share the same supply rail, or the same mains connection, or the same distribution networks, or the same power plant, etc.
Plus, look at how impressive PSRRs and cross-talk attentuation modern op amps have, .
Single or Dual opamp package?Hide this!Advertise here!
Pass Discrete Opamp in DIP-8 Package EUVL Pass Labs 117 9th May 2017 03:25 PM
JRC 45580 opamp..dual or single?? tone Digital Source 3 30th April 2003 06:21 AM
single so8 to dual dip opamp adapter available from BrownDog morsel Solid State 18 1st June 2002 07:34 PM
Copyright ©1999-2017 diyAudio
