Recommend amp project for new member - Page 2 - diyAudio
Old 16th October 2013, 01:31 PM   #11
DOXA 40 is a class A/B amp. and 40W class A. it might be this one he got.
Old 16th October 2013, 01:34 PM   #12
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
(that would be very cool running 40watt classA)
but his is clearly dual mono ?
sometimes we know very little, and sometimes we know too much
Old 16th October 2013, 01:40 PM   #13
as i understand it. it is a dual mono with dual 500VA 2*31V transformers. wish also backs up the 40W class A power. and the chassis is huge.
so this can be used for class A amp. or bridged/X'ed class A/B amp
Old 16th October 2013, 01:43 PM   #14
Hi guys,
It's a Doxa 70 from (I think) 1979 or thereabouts. It's dual mono, with two toroids and a big chassis with heat-sinks serving as the side members of the enclosure.
Thanks!
Henrik
Old 16th October 2013, 02:10 PM   #15
KatieandDad's Avatar
It's amazing what you find if you go looking hard enough.
Old 16th October 2013, 02:40 PM   #16
Henrik. i think you have to post some pics
Old 16th October 2013, 03:00 PM   #17
Originally Posted by Henrik76 View Post
Hi guys,
Thanks!
Henrik
heatsinks appear like real heavy duty
but keep in mind that finning is rather short
lowers effiency more than you might think
but big enough to keep a classAB safe into low 2ohm load
Old 16th October 2013, 03:17 PM   #18
40W of ClassA into 8ohms requires a peak ClassA output current of 3.2Apk
The quiescent current of the output stage would need to be set to ~1.6A to achieve that 40W, i.e. 320mA through each of those ten 0r56 emitter resistors. That is 179mVre
Could the bias be set that high?
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 16th October 2013, 03:31 PM   #19
there is atleast 4 Versions of this amp. SE mkI, SE mkII, signature mkI and signature mkII.
Old 16th October 2013, 03:55 PM   #20
Those heatsinks would work far better if the fins were vertical.
recommend high power project? DavidNChin Class D 1 26th October 2010 11:23 AM
Recommend a project for a n00b Bass Character Tubes / Valves 3 11th March 2009 02:48 PM
Recommend amp project for Vandersteens joshzero Pass Labs 14 9th September 2007 05:07 PM
recommend me my first diy project? nef Multi-Way 1 14th August 2005 03:56 PM
recommend an internal DAC project mlloyd1 Digital Source 10 11th March 2002 07:52 AM
Copyright 1999-2017 diyAudio
