How to make a low distortion lateral MOSFET amplifier?
Old 12th November 2013, 12:28 AM   #151
danny92 is offline danny92  Portugal
Hi rsavas and thank you for your great help,
Do you think that I should do both channels (the amplifier is stereo) in the same PCB or I should make two PCBs?
The preamplifier and other tone controls must stay in this main PCB(s) or in another one, what about the power supply bridge rectifier and capacitors?
I will use this relays, how I can simulate the optocoupler before adding them to the PCB, I wanted to simulate this relay with the optocoupler, how I can simulate this circuits in LTSpice?
ESP - MOSFET Solid State Relays
Best regards,
Daniel
Old 12th November 2013, 05:21 AM   #152
rsavas is offline rsavas  Canada
Up to you/ I guess that it depends on the size.
That I do not know.
Old 13th November 2013, 04:07 AM   #153
Unhappy Need help!!!
Hi everyone,
I can't begin the PCB design right now because I still have some problems and doubts,
The main problem is that it seems that I've instabilities in internal nodes, I've added a few pictures about the strange responses of those nodes, even at the output there's a peaking starting at about 200 MHz.
The other problems are related to the current sources that are varying too much with temperature and the fact that I don't have thermal compensation for the drivers.
I don't know how to simulate an NTC thermistor in LTSpice and I want to simulate the thermal shutdown circuit, now that I've the output solid state relay, I also want to add a poping prevention delay network to connect also to the output relay, how I can connect all those things to the output relay with an OR logic gate?
The solid state relay I'm using is based on Rod Elliot's designs ESP - MOSFET Solid State Relays
Do you have some ideas about the startup delay circuit?
I really need your help, I can't move on with this project and make the PCB without achieving stability in the simulations.
I also need help with the stability problems, it's very important it's making me mad, because the amp has good gain/ phase margins but seems to have strange behaviours in the internal nodes. Why?
Please someone help me here!!
Thank you very much for your attention,
Best regards,
Daniel
File Type: jpg Amp7_btmc_hb5_s_bd12_prot_solid_state_output_relay.jpg (193.7 KB, 101 views)
File Type: asc Amp7_btmc_hb5_s_bd12_prot_solid_state_output_relay.asc (30.5 KB, 13 views)
How to make a low distortion lateral MOSFET amplifier?Hide this!Advertise here!
VSSA Lateral MosFet Amplifier Lazy Cat Vendor's Bazaar 3463 13th August 2017 04:37 PM
Really simple lateral mosfet amplifier Tekko Solid State 11 25th March 2013 07:31 PM
Midgård, compact, low distortion, high quality, Class A Lateral FET headamp Neutrality Headphone Systems 23 12th March 2013 06:21 PM
Midgard, a low distortion Lateral FET output Headphone Amplifier Neutrality Headphone Systems 8 14th December 2012 08:31 PM
200W Lateral Mosfet Amplifier macgyver Solid State 5 7th July 2003 08:49 PM
Copyright ©1999-2017 diyAudio
