GLA (good little amp) "survivor"
Old 10th October 2013, 03:30 AM   #11
wahab is offline wahab  Algeria
Very nice and refreshing amplifier considering the "current"
subjectivists tendencies , it should allow very good perfs
that might well surprise some esoterics design afficionados...
No doubt that i ll give it a try in the simulator...
Stability would be greatly improved with say a 22pf from
collector to base of Q7.
Also , what happened to Q7/Q11.?.?..
Old 10th October 2013, 04:54 PM   #12
wg_ski is offline wg_ski  United States
That 22pf would add what would normally be a 'cdom' - in this case, extra phase shift. Since the amp is already lag compensated (R7 C5) this may or may not help stability. If you remove the lag comp, you need it or else. And maybe a higher value would be advisable.
Old 10th October 2013, 05:30 PM   #13
ostripper is offline ostripper  United States
ostripper's Avatar
Default Sansui 3900/5900
Here is the "truth" .
Attachment 1 is the amp section. The input stages (I tested them) are run by
a +/- 18VDC supply. It is strange they regulate the positive 18v from the amps main
V+ rail and derive just the negative 18V for Q1-2 from an auxiliary supply.
I might "clean up" the differential supplies and create two zener regulated
ones instead , it will make for a "standalone amp".
This is really a Sansui Z3900 , the PDF is too big.
You will notice the Sansui had a DC servo - I changed this into it's passive
equivalent.
OS
Wanderer - my travels.... Facebook - davyjones lockre -
Old 10th October 2013, 06:43 PM   #14
ostripper's Avatar
Default Zener supplies
Very good !
Lower distortion .... .008% THD20K 8R
Used 15V zeners with 2 simple follower trannies (below).
One pair of differentials (Q1-2) sees 12v and the other (Q3-4) 35V.
Many choices here !
Sansui made some economic choices and just "stole" existing supplies
for the differential to save $$$$ .
Much more stable , I can change the Q1-2 Ic over a much wider range without
oscillation now ,as well.
PS - scaled down R8-9 to 3K3 to keep things "vintage".... (-14.4VDC instead of -18VDC)
OS
Old 10th October 2013, 07:52 PM   #15
ostripper's Avatar
Default OMG -Q7 and 11
But it actually simulated right -
I fixed this - and wow ! .001% 20k.
- Tiny glitch in the stages is gone , and the loop gain is "more normal"
(typical) 500k UG with 80+ margin....
-Q1-2 nearly superimpose (balanced)
-Q1-2 are 1ma , Q2-3 are 2ma , the VAS is 3ma.
The actual amp measures real close to this.
This is almost ready to FLY! (pcb)
PS- this amp's topology was actually able to compensate for 2 swapped E-C's !
New .ASC (below)
OS
Old 11th October 2013, 05:17 PM   #16
ATAUDIO is offline ATAUDIO  Austria
Hi, OS!
Very nice amp, indeed.
Probably I did not get it right, but it isn't a little too much 50 V rails for a single pair? I see that you have used good robust ONSemi outputs, but you can be sure that sooner or later somebody will hook some 4 Ohm speakers on it.
I would be tempted to put 3 pairs on output and call it a good 250 Watter!
@Audio
Old 11th October 2013, 09:01 PM   #17
ostripper's Avatar
Originally Posted by ATAUDIO View Post
Hi, OS!
I'll design a single pair MJL21193/94 version first. Using the triple OP stage
demands it. That should give about 80W/channel (8R) ,the MJL's soa would also be good enough for a 4R load at 40V rails.
Solved the compensation issue. Standard miller comp. with a B-C capacitor
won't work with this amp !
Phase compensation -(R7/C5) of the first differential plus a little lead compensation from the VAS (R6) let's you "shape" the phase margin and unity gain point of the amplifier response curve. Harder ! , but a more elegant
approach. Original "vintage" (47R and .0022uf) values still gave a stable amp.
(below attachment)... this amp is compared to the standard "blameless".
Latest .ASC below - (with the "vintage" parts modeled) the performance came out real close to the OEM specs - but just a little better.
OS
Old 11th October 2013, 09:45 PM   #18
ostripper's Avatar
Default 400W "monster version"
Scales up VERY nicely. No troubles with THESE "tribbles" (triples).
- 6 pairs 21193/94
OS
Old 13th October 2013, 04:28 AM   #19
ostripper's Avatar
Default GLAv1.2 (final)
All is wonderful ...
V1.2 is SO close to the Sansui 3900 , both in compensation and actual voltages.
(Attachment 1) is the final work.
My tweaks to C6 (lead comp.) and the "lag" comp. (R7/C5) are within range
of the original specs.
The simulation also allows for higher Hfe Zetex devices , 2n5401's , 2sa992's
or any other to-92 device for Q1-4.
Any to-220 (mje15032/33 , 2sa1837/2sc4793) as driver , and any OP device
..including the low gain/low Ft mjl21193/4... work very well with this amp.
R25 and 26 load the VAS , which gives a monotonically decaying harmonic
output.
The differentials and VAS are at such low current (no heatsinks),
I can squeeze this into a 76 X 102 mm board for the 70W version (attachment 2).
The main board will use njw TO-3P's as drivers !!
For those who want the "Frankenstein" version , attach the "GLAeX" PCB
(attachment 3).Run your 80V rails, you will have a 400W true triple OPS.
Also , the final .ASC is also below.
PCB's + the BOM will be done in the next few days.
OS
Old 13th October 2013, 07:36 AM   #20
lloop9 is offline lloop9
Wow, very nice map OS! The "Frankenstein" version is going to be my next project.
By the way, the name 'Survivor" reminds me of the 80s band that did the theme song "Eye of the Tiger" for Rocky III, a fitting name for a simple, rugged & quality amp.
GLA (good little amp) "survivor"Hide this!Advertise here!
Need a good recommendation on a "great" sounding 7.2 surround amp Thaedge Solid State 0 10th March 2011 03:49 PM
Highbred Amp "TUMOS" Sounds good? ataul Tubes / Valves 1 25th April 2010 11:51 PM
The "Cheap, but good" rectifier & diode thread. Spasticteapot Parts 8 21st March 2006 02:44 AM
Is this "el cheapo" Velleman100wRMS kit good enough for a subwoofer amp? Spasticteapot Solid State 5 17th March 2006 09:09 AM
BOZ to Gainclone (LM4780) ? is that a "good" thing zei Pass Labs 5 10th April 2005 11:47 PM
Copyright ©1999-2017 diyAudio
