200W MOSFET CFA amp
200W MOSFET CFA amp
Old 24th July 2014, 12:03 PM   #521
dadod is offline dadod  Croatia
dadod's Avatar
Originally Posted by astx View Post
Of course it does - one must decide what is more important.
OTOH my real life measurements THD+N 20k@200W@8R (bw 80k) - 0.0016% are made including this diode - so what are we talking about...
I like your work and your ideas, but technically I can't agree with you on that, it is the worst place to control the clipping (VAS). Reversed biased diode acts as a varicap diode with very non linear capacitance change. If you do all to get low distortion then adding that diode increases distortion not just few ppm, but a lot. In my simulation I used MMSD4148 diode with very low Cjo = 0.64pF (sorry I don't have BAV21 model) and THD20k increased from 1.57 ppm to 9.74 ppm at output level close to clipping.
This is 6.2 times or 15.8 dB. Of course if an amp is with higher distortion then the diode distortion could be masked.
By the way, adding a zener as suggested did improved distortion and clipping behavior, but just a little, so one can decide to use it or not, the protection resistor is a major player here.
cheers Damir
Old 24th July 2014, 01:19 PM   #522
R.I.P.
Would a series pair of diodes still work in reducing the glitch as clipping is approached and passed?
The series pair would automatically halve the capacitance.
regards Andrew T.
Old 24th July 2014, 01:50 PM   #523
astx is offline astx  Austria
200W MOSFET CFA amp
Have had the same idea but has not worked for me. The clipping behavior at 20kHz was "bad" again and the distortions were higher.
Old 24th July 2014, 02:21 PM   #524
R.I.P.
Probably too much voltage across the series pair to suppress the saturation effect.
regards Andrew T.
Old 24th July 2014, 02:33 PM   #525
200W MOSFET CFA amp
cheers Damir
You are right - I always have said "one can decide". The zener variant is a very good compromise as you can now use low Vce devices to get better distortion and clipping behavior.
Even in my simulations it worsens the distortions from 4ppm (20k@200W@8R) to 15ppm near full power. At 20k@50W@8R the simulated distortions are 4.6ppm versus 5.7ppm with diode. During real life measurements I have tested with and without diode - the distortion level was always the same - maybe due to limits of my measurement devices or due to bad diode simulation models.
Attached a screenshot of BAV21 capacity versus reverse voltage.
1.15pF (0V) to 0.9pF (14V)
As we can see the worst (and nonlinearest) change rate of capacitance are the first 4 V - these affect the distortions mostly the last 4V be4 clipping of the positive halfwave. During small signal listening the diode is reversed biased about 1/2 of total supply voltage with negligible capacitance changes.
BTW: BAV21 model is from Phillips/NXP:
see NXP website: http://www.nxp.com/documents/spice_model/BAV21.prm
.MODEL BAV21 D
+ IS=21.910E-9
+ N=2.2330
+ RS=1.0000E-3
+ IKF=19.230E-3
+ CJO=1.0300E-12
+ M=.1001
+ VJ=.75
+ ISR=10.010E-21
+ BV=293.10
+ IBV=1.2930E-3
+ TT=51.940E-9
Hope this helps for a decision.
BR, Toni
Old 24th July 2014, 02:37 PM   #526
200W MOSFET CFA amp
Old 24th July 2014, 04:09 PM   #527
dadod's Avatar
.MODEL BAV21 D
+ IS=21.910E-9
+ N=2.2330
+ RS=1.0000E-3
+ IKF=19.230E-3
+ CJO=1.0300E-12
+ M=.1001
+ VJ=.75
+ ISR=10.010E-21
+ BV=293.10
+ IBV=1.2930E-3
+ TT=51.940E-9
BR, Toni
I simulated with BAV21 and got almost the same result, a bit lower, 9.18 ppm, thanks for the model.
I think If you really need to better clipping behavior the is better to use Backer clamp.
BR Damir
Old 24th July 2014, 06:35 PM   #528
BV is offline BV  Slovakia
dadod
Try to solve clipping behavior just in differential input stage, with antiparalell 1N4148 diodes between colectors of curent mirror transistors (some resistor for voltage shift in series with colector Q6 will be needed, without input signal should be across diodes zero voltage).
Or simply connect 3 diodes (1N4148) in series to Q15 base (first cathode) and +Ub of VAS -upper side R18 (last anode), remove Q20 and slightly increase R29 .
Old 24th July 2014, 08:33 PM   #529
dadod's Avatar
Originally Posted by BV View Post
dadod
Thank you BV for your suggestion. I tried both and here is the result.
Antiparallel diodes between CM transistor collector did not improve clipping.
Diodes string between EF VAS transistor base and +Ub did help with the clipping behavior if EF protection resistor was set to low value (1k), and did not improve it when that resistor was high enough (10k to 15k) but doubled distortion.
Damir
Old 24th July 2014, 09:41 PM   #530
200W MOSFET CFA amp
BR Damir
Baker clamp hasn't helped to cure the 20k clipping as we have a amplifier with NFB. IMHO if you add the baker clamp the VAS still gets into saturation as the NFB wants to correct the heavy distorted output signal. Diode clamp between input LTP hasn't helped either - only increased distortion.
Maybe you get here better results with your CFA using a baker clamp.
BR, Toni
200W MOSFET CFA ampHide this!Advertise here!
What about this amp-CFA or VFA? dadod Solid State 22 31st March 2015 12:08 AM
200W mosfet Amplifier sanbadgujar Solid State 20 31st August 2012 07:46 AM
F/S Transcendent Sound CFA amp. doorman Swap Meet 4 5th April 2012 12:09 AM
My 200W/4 class AB MOSFET amp. sparkybg Solid State 20 21st July 2005 07:39 AM
200W Lateral Mosfet Amplifier macgyver Solid State 5 7th July 2003 07:49 PM
