Jfet Idss Tester - diyAudio
Old 1st October 2013, 02:36 AM   #1
Ripcord is offline Ripcord  United States
Ripcord's Avatar
Default Jfet Idss Tester
Is this the correct method? I followed Nelson Pass's description, or at least I'm hoping I did. ( "I connect the Source and Gate to ground (for N) and measure the current.
With an 11 volt supply and assuming a typical value of 10 mA, use 100 ohms
in series with the Drain (the voltage drop across it will give you the Idss) for
a Vds of about 10V, and connect the other side of the resistor to +11V.
Reverse the supply polarity for P channel." )
Old 1st October 2013, 03:00 AM   #2
DUG is offline DUG  Canada
Watch the power dissipation.
BAD is when they are too hot to touch.
Otherwise, yes this will work fine.
Doug We are all learning...we can all help
"You can't stop the signal, Mal. Everything goes somewhere..."
Old 1st October 2013, 04:26 AM   #3
Ripcord's Avatar
Just to follow up, this is the first time I have matched Jfet's. Out of twenty fets, here's the results in mA's:
2 x 5.00
2 x 6.16
2 x 4.82
then:
6.59
6.37
5.85
5.86
5.71
6.19
6.44
6.07
6.11
5.09
4.86
4.13
4.92
4.40
Is this pretty typical? The Jfet is a 2N5952. I needed four matched pairs.
Old 1st October 2013, 09:16 AM   #4
Send a message via Skype™ to JonSnell Electronic
Your load resistor is the wrong value. Should read 1k for 10mA otherwise 100R will draw 100mA.
POP!
www.flyingmole.co.uk For World Wide support for Flying Mole, Class D, Refurbishment and Repairs. www.jonsnell.co.uk
Old 1st October 2013, 10:18 AM   #5
CBS240 is offline CBS240  United States
CBS240's Avatar
Actually the transistor will draw Idss, but the majority of the supply voltage will be Vds. 6.59mA X 100R= 0.659V. 10.341V X 6.59mA= 68.2mW. Should be OK for even a SOT-23 J-fet. A higher goss J-fet like J111 or 2N4091 might begin to get warm. It is best to try to have relatively the same Vds for each DUT so you don't want it too large, but large enough to get an accurate measurement. 100R is fine here.
The self bias with or without a source resistor is why J-fets make such great current sources, especially when cascoded.
All the trouble I've ever been in started out as fun......
Old 1st October 2013, 05:44 PM   #6
tom42107's Avatar
One last question, what is a reasonable difference for considering being matched? For instance, is 6.11, 6.16 and 6.19 close enough?
Old 1st October 2013, 08:35 PM   #7
Triodethom's Avatar
That 1% low and 1.5% approx high . Given 1% resistors I say that a good match.
What is the correct Idss of jfet? Sunsun22 Parts 5 9th January 2011 12:31 PM
High Idss 2SK170GR? Sweetsweetback Parts 2 31st October 2010 11:40 PM
JFET question - Idss values JammyBStard Solid State 14 6th January 2010 01:54 PM
JFET Tester jackinnj Equipment & Tools 4 9th August 2008 04:43 PM
JFET Tester jackinnj Equipment & Tools 2 4th April 2007 05:27 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
