JLH Updated version in progress
Old 17th December 2003, 11:42 PM   #11
Devil_H@ck is offline Devil_H@ck  Belgium
Devil_H@ck's Avatar
Send a message via ICQ to Devil_H@ck Send a message via AIM to Devil_H@ck Send a message via MSN to Devil_H@ck
Default Re: use car-light bulbs for load
Originally posted by dutch diy
pcb for a regulated powersupply is available on my site amp
The PCB I am designing is for another circuit. Take a look at the first post .
A decent load to test a PSU can be made out of car-head-light bulbs.
They are usually 12V 50W so two in series makes a bright 24V 50W load.
Thanks for the tip!
Old 18th December 2003, 09:42 AM   #12
Devil_H@ck's Avatar
Ok, everything's looking good on the PCB, I guess I'll make it today. I only need to put the screws a little bit farther from the 2 MJ15003's.
Oh, I was wondering. How do I connect something to the collector of the MJ15003? There's no pin for it, it's just the case. Do I need some kind of bar to stick trough the PCB and solder it to the underside & the case?
Or am I totally wrong asuming that these MJ15003's don't need cooling in this case?
Old 18th December 2003, 10:11 AM   #13
Andypairo is offline Andypairo  Italy
Andypairo's Avatar
Yes you are
These BJTs pass the whole current delivered to the amp, so they must be heatsinked.
Cheers
Andrea
Old 18th December 2003, 10:18 AM   #14
Luke is offline Luke  New Zealand
Send a message via AIM to Luke
Hi Devil_H@ck,
You can get solder tags that have an eye for a 3mm screw. Use two nuts, one to mount the transistor and the second to sandwich the tag. Then solder your wire to the tag.
Good luck and nice pcb BTW
Old 18th December 2003, 10:31 AM   #15
Samuel Jayaraj is offline Samuel Jayaraj  India
To reply your question - one of the mounting screws for a TO3 pack should make contact with the case of the semiconductor BUT NOT the heatsink. An eyelet passing through this screw can be used on the track side of the PCB to complete the electrical connection. The transistor itself should be isolated electrically from the heatsink. Check the photographs of various projects in this forum to get an idea.
Sam
Old 18th December 2003, 02:20 PM   #16
Devil_H@ck's Avatar
Thanks for the tips!
Old 18th December 2003, 07:00 PM   #17
Devil_H@ck's Avatar
Typical . I can't find my cutting disks, great... That, and both my 0.8mm are broken. Oh well, I'll buy some tomorrow .
Old 18th December 2003, 10:11 PM   #18
Devil_H@ck's Avatar
Default Wohoo!
Great! Guess what I found behind a pile of women's magazines . Cutting discs!
This is the best PCB I've ever made (ok, it's only the 3rd I did, so what ). Even the sides are straight, well, except for the two I had to cut with the dremel . You can even read the tiny words I put on it: "AVH '03" (= Anthony Van Herrewege 2003) and "JLH PS" (= JLH Power Supply). Well, my name is not that readable, but that's because that part of the PCB was between 2 UV lamps and the part with the "JLH PS" was right above one.
Here's the PCB:
Old 18th December 2003, 10:17 PM   #19
millwood is offline millwood  United States
Account Disabled
Default Re: Wohoo!
what do you have those magazines for?
Cutting discs!
Here's the PCB:
Nice PCB. How do those cutting discs work?
Old 18th December 2003, 10:29 PM   #20
dutch diy is offline dutch diy  Netherlands
dutch diy's Avatar
Send a message via ICQ to dutch diy
Default TO-3 insulation
Of the shelf "isolation-sets for TO-3" contain pads, nuts & bolts soldering-eye and plastic washers to securly tighten your TO-3 to the case and leaving a soldering eye to connect from the bottom to the housing of the device.
JLH Updated version in progressHide this!Advertise here!
Updated my website pmillett Tubes / Valves 7 24th December 2008 02:03 AM
who's updated their dcx2496 to vs1.16? roburg Digital Line Level 1 23rd November 2008 05:07 PM
5 volt version of the Updated super regulator. audiodoc Parts 18 27th March 2006 04:32 PM
2 x tda1541as1 dac updated tone Digital Source 2 24th April 2003 04:12 PM
Web site updated Andy G Multi-Way 0 24th July 2002 05:40 AM
