What does this do? - diyAudio
Old 25th September 2013, 03:37 AM   #1
pmchoong's Avatar
Default What does this do?
This (image) was taken out from the Krell KSA50 clone. I have a few questions :
1) Does this improve the sound quality of any other system?
2) Or is this only for the Krell KSA50 clone?
3) What does it do?
Thanks.
Old 25th September 2013, 04:06 AM   #2
It is there in most amps. It prevents the power amp instability, if the load is too much capacitive. Even the speaker cable can be responsible for this.
Gajanan Phadte
Old 25th September 2013, 05:34 AM   #3
KatieandDad's Avatar
It's a Zobel Network, as gmphadte says above.
Old 25th September 2013, 07:09 AM   #4
He is asking about the R206 and L201
Gajanan Phadte
Old 25th September 2013, 07:18 AM   #5
balerit is offline balerit  South Africa
balerit's Avatar
R205 and C201 is the Zobel network.
Old 25th September 2013, 07:26 AM   #6
Mooly's Avatar
And no one has told him what they do yet...
L201 isolates the amplifier from capacitive loading by virtue of the rising reactance of L201 at HF. In other words it appears as a small "resistance" in series with the amplifier output at HF, and the higher the frequency the higher the "resistance".
XL (its resistance) = 2pi fL and so a typical value of 4uH would appear as a "resistance" of 2.5 ohms at 100kHz. It isolates the amplifier.
The parallel resistor "damps" any ringing that the coil would cause on squarewave testing.
R205 and C201 terminate the amplifier with a known and predictable load at HF.
Old 25th September 2013, 07:56 AM   #7
pmchoong's Avatar
Thanks a lot, guys. I really appreciate your replies. But shouldn't L201 and R206 on the opposite side as well?
Old 25th September 2013, 08:08 AM   #8
pmchoong's Avatar
Could it be better if they are on both sides as in the image attached?
Old 25th September 2013, 08:17 AM   #9
Mooly's Avatar
That wouldn't work. As you have drawn it the effect of C201 is pretty much negated by the series L201 although the parallel 4.7 ohm would still allow C201 to provide some effect though.
You sometimes see a double network with another pair of R205 and C201 on the output side of the inductor so they appear directly across the output terminals.
Old 25th September 2013, 08:20 AM   #10
JonSnell Electronic's Avatar
No, because the coil and resistor have a reactance that will cancel the predictive loading on the amplifier at high frequencies and may cause instability.
Support for Fender, Marshall and all Valve Equipment; Audio Innovations, Audiorama FU29, Quad and Leak. www.jonsnell.co.uk
Copyright 1999-2017 diyAudio
