TO-3 16 HeatSink - diyAudio
Old 17th September 2013, 07:18 PM   #1
Krisfr is offline Krisfr  United States
Krisfr's Avatar
Default TO-3 16 HeatSink
What would be a good CFA project to use this heatsink with?
Each of the four quadrants are electrically isolated from the frame and the others.
Never give a Systems Analyst a screwdriver or hammer
Old 17th September 2013, 07:42 PM   #2
wrenchone's Avatar
Looks like the basis for a big classA amp, say a Pass A75 if you can find the TO-3 mosfets.
Old 18th September 2013, 06:53 AM   #3
jacques antoine's Avatar
What's running into the center core pipe? Liquid nitrogen ?
Old 18th September 2013, 07:46 AM   #4
wrenchone's Avatar
The center pipe coincides with the center core/motor of your usual axial fan, and keeps the airflow from the fan blades confined to the heat sink fins, where it belongs...
Old 18th September 2013, 04:57 PM   #5
rsavas is offline rsavas  Canada
TO-3 mosfets.
Alfet makes latfets in to-3, newark/farnell(uk)
T0-3P package should also fit in place of a TO-3
Old 18th September 2013, 05:07 PM   #6
wrenchone's Avatar
Exicon mosfets would also be an option, as they still make TO-3 devices in both flavors. It would be a departure form the original A75 design, but would still work.
Old 18th September 2013, 08:08 PM   #7
Krisfr's Avatar
Thanks for all ...
I am looking for a AB amp of about 250 or 300 watt with Current feedback or dual differential, I have a Dynaco 400 heatsink too but less transistor positions. Maybe I could drill some more and double my outputs, hummmm...
Old 19th September 2013, 12:40 AM   #8
djk is offline djk
djk's Avatar
416 uses the same sinks as the 400, just drilled for more outputs.
Candidates for the Darwin Award should not read this author.
Old 19th September 2013, 11:50 AM   #9
3pair of 250W BJTs will give ~ 300W of maximum output.
3pair of 150W mosFETs will give ~220W of maximum output.
With the blowers operating well, the Tc will be lower than for a passively cooled amplifier. This could allow higher maximum output powers than stated above. I wonder if a sensible target would be 150%?
regards Andrew T.
Old 19th September 2013, 12:54 PM   #10
Krisfr's Avatar
The MJ21194 has an Ft of 4 Mhz. I am leaning toward them, but would like use a better one than this one if it is available. I can put 4 pair on each channel so using the formula of Andrew T I could go up to about 400 a channel, but the power supply would be Huge. Any other thoughts on a better device would be welcome, I am not stuck on ON-Semi, but I do not want to go to mosFet either.
BD139-16 & BD140-16? Anyone use these transistors? grhughes Parts 44 29th September 2013 09:56 AM
Heatsink vs heatsink + fan. nigelwright7557 Solid State 3 11th March 2013 11:04 AM
Studiomaster 16-16-2 schematic chitownrocker Instruments and Amps 8 22nd January 2012 12:27 AM
FS: Calrad SV-16 16" Transcription Tonearm (Grace Oil Damped Tonearm) dnewma04 Swap Meet 1 24th November 2011 12:45 AM
Replacing NE5532 and TL07x in a Soundmaster 16-16-2 mixer synthguru Instruments and Amps 4 25th March 2011 11:06 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
