Audio amplifier with 2n3005
Old 11th September 2013, 04:12 PM   #1
Gost22 is offline Gost22  Bolivia
Banned
Unhappy Audio amplifier with 2n3005
Hi guys!
View schemeatics this amplifier for which the author gives this
Specifications:
Power output is 60 watts into 8 Ω and 100 watts into 4 Ω loudspeaker.
Total harmonic distortion is less than 0.01 %.
Frequency range is within 20 Hz and 20 kHz.
The input sensitivity is in the vicinity of 750 mV.
The frequency characteristics lie in between 1 dB from 15 Hz to around 100 kHz.
If all this is okay?! What changes in the schematic needs to be done for this audio amlifier with power supply Ucc=+/-38V and with the output transistors MJ15003/MJ15004?
Thank you for your cooperation!
Old 11th September 2013, 04:59 PM   #2
Osvaldo de Banfield is offline Osvaldo de Banfield  Argentina
Osvaldo de Banfield's Avatar
Location: Barrio Garay,Almirante Brown, Buenos Aires, Argentina
Supposing the transistors can support the voltages and currents, I don't see any important mod, perhaps R4 and R5 to maintain current in leds. The other parts are feed in constant current, so no mod necessary. Check also capacitor voltages rating (50V, mainly C6, C7 and C5).
But the schematic looks some strange. Did you forget R and a C in series from left side of R9 to ground? As is, the amplifier is unity gain.
Osvaldo F. Zappacosta. Electronic Engineer UTN FRA from 2001.
Argentine Ham Radio LW1DSE since 1987.
Old 11th September 2013, 07:45 PM   #3
jaycee is offline jaycee  United Kingdom
If you can use NPN/PNP power output transistors then you dont really need a quasi-complimentary circuit like this one. A basic Blameless type circuit will work fine.
Old 12th September 2013, 12:05 AM   #4
Banned
What are the transistors in the schematic?
thank you!
Old 12th September 2013, 02:32 AM   #5
They aren't specified but the following should work:
TR1,2,3 = BC556
TR4 = MJE340
TR5 = MJE350
TR6 = MJE15032
TR7 = MJ15003
TR8 = MJE15033
TR9 = MJ15004
TR10,11,12 = BC546
TR13 = BD139 (mount on main heatsink)
Old 12th September 2013, 03:40 AM   #6
Samuel Jayaraj is offline Samuel Jayaraj  India
The schematic in post#1 is very similar to a circuit published in Elektor just after the release of the Crescendo and Mini Crescendo designs, except that instead of LEDs, the CCS were referenced with zener diodes. I had built several of those amps and thought they sounded very good for their time, especially with a fully regulated PSU.
Sam
Old 12th September 2013, 04:24 AM   #7
Banned
Hi Samuel!
If you are unable to view the schematics.
thank you!
Old 12th September 2013, 05:45 AM   #8
Banned
Default PCB for this audio amplifier
Hello!
Mr. Yaycee please show your PCB for this audio amp if you have one.
Thank you!
Old 12th September 2013, 06:51 AM   #9
alayn91 is offline alayn91  France
alayn91's Avatar
Hello,
Unfortunately, in post n1, I'm afraid T10 is useless, with its Vbe = 0V.
Old 12th September 2013, 09:43 AM   #10
Banned
Originally Posted by alayn91 View Post
Hello,
That's it! is missing something, but what?
Audio amplifier with 2n3005Hide this!Advertise here!
Schematic: Audio Innovations, The first audio amplifier maartentje Tubes / Valves 28 12th July 2016 12:41 PM
Audio Amplifier wkahc Introductions 1 31st August 2007 06:01 PM
Audio Amplifier VoLCoM Chip Amps 2 9th July 2005 01:42 AM
audio amplifier mephisto Car Audio 2 21st January 2004 04:52 AM
