Rasing toroid transformer off the chassis
Old 10th September 2013, 04:57 AM   #1
ClefChef is offline ClefChef  United States
ClefChef's Avatar
Default Rasing toroid transformer off the chassis
Due to space constrains it is sometimes difficult to fit the power transformer into the chassis. I tried "hanging" the transformer from the top lid, but that creates all kinds of connectivity problems. I also tried raising the trafo on the bolt as see in the attached picture, it does not touch any PCB's - any problems with this solution?
This is my JC-2 clone preamp with remote - it sounds excellent, no noise.
Old 10th September 2013, 10:41 AM   #2
ingenieus is offline ingenieus  South Africa
Just make sure that the bolt holding the transformer does not touch the top and bottom of a conductive enclosure at the same time. That would be a bad thing. It will make a single turn in the secondary winding that is short circuited. This will then melt the primary winding because it cannot deliver the current demanded.
Rasing toroid transformer off the chassisHide this!Advertise here!
Using a large 60hz toroid transformer as an SMPS transformer EWorkshop1708 Power Supplies 20 22nd June 2011 08:05 PM
Toroid Trans and empty chassis Dick West Swap Meet 10 11th August 2008 12:01 PM
Empty Chassis with Toroid Trans Dick West Swap Meet 3 28th March 2007 03:03 PM
toroid Transformer as power Transformer for tube tone Tubes / Valves 7 11th February 2003 08:57 AM
toroid Transformer as output Transformer for tube preamp? tone Tubes / Valves 15 2nd February 2003 04:36 AM
Copyright ©1999-2017 diyAudio
