no mercy distortion killer circuit - Page 11 - diyAudio
Old 6th January 2004, 08:37 PM   #101
traderbam's Avatar
Here beside the local feedback of each amp, there is a one way path from left to right and the signal travels one time only, not in circles.
Are you assuming that the output of the right-hand amp does not affect the output of the left hand amp?
Suppose the amp output voltages are Vl and Vr respectively, and say the correct output is Vo.
You are saying that you make Vr = (Vl - Vo) so that the voltage across the speaker is Vl - Vr = Vl - (Vl - Vo) = Vo. Perfect!
This cancellation assumes Vl is not changed by Vr. But you must agree the current through the speaker changes with Vr. So if Vl remains the same when the speaker current changes the output Z of the left amp must be zero. Which is impossible. So what happens is Vr adjusts Vl slightly and this causes a small change in Vr and this causes Vl to change and so on...and if you are lucky it converges.
Feedback is born!
Old 6th January 2004, 09:02 PM   #102
Bernhard's Avatar
However, the sim is very promising
Old 6th January 2004, 09:14 PM   #103
johnferrier's Avatar
I think what most people do is to try to make the left side have the least amount of distortion (or at least an agreeable distortion shape--meaning I know that people try to minimize "high order" distortion, which your design may be more prone to, but I don't know...). Then people figure that something like the right side will introduce more distortion than it cancels.
Another thing, it doesn't seem like a lot of people have actually tried this feedforward design, so perhaps you will learn something interesting (that the rest of us don't know about). This probably leads to other interesting discoveries.
JF
Old 8th January 2004, 08:04 AM   #104
thanh is offline thanh  Viet Nam
thanh's Avatar
Send a message via Yahoo to thanh
digilander.libero.it/paeng/feedforward_concepts.htm www.angelfire.com/az3/dimitri/List.htm
Old 8th January 2004, 08:16 PM   #105
Default Lighter than air and faster than light...
My first observation is that the proposed topology attempts distortion cancellation by duplicating the original amplifier as a canceller and feeding it with an error signal, the cancellation occurs because the canceller is replacing ground at the load. This isn't an original concept, but its fun to work with.
The simulated THD numbers I've seen posted here won't hold up in practice, and wouldn't prove useful if they did...
1) The op-amp macro-models the Spice based simulator is using don't attempt to model distortion, and may not be simulating the internal delay times and slew rates inside the op-amp. Without the internal delays, many complex control loop topologies simulate as working well, when in fact they will oscillate. Switching to an accurate transistor based model will get both the delay and distortion. If one isn't available for a particular op-amp, choose one a full circuit transistor based model is available for. These models often have slow convergence because of the high internal gain and feedback, and if the overall circuit is unstable there may be a problem simulating it. Use a transient analysis to ramp up the DC supplies without a signal and, assuming it reaches a steady state, use the resulting node voltages to preset the bias point for the simulator for the other analyses.
2) The circuit is exploiting a level of symmetry only found in the simulator. When built, the parts will vary. Not just the resistor tolerances, the transistors, op-amps, and so on. It is important to determine the key sensitivities and their effect or do some monte-carlo simulations. This is a limiting challenge for a feedforward design that makes it difficult to create a composite device that dramatically improves on the performance of the error amplifier. As you refine your design you need limit the number of parts that need to be matched pairs, and how well matched they have to be to achieve some realistic goal for distortion. A good first step would be to determine what matching is needed to achieve a composite amplifier 10dB better than the error amplifier.
3) Non-linear effects that aren't being modelled will prevent the design from achieving numbers like -156dBc. For example; capacitors have a voltage coefficient, you can find specs for various types and its a parameter for the spice model. There is also an effect called "dielectric absorbtion" which is more difficult to get the numbers for and more complex to add to the circuit model. Dissimilar metal junctions, e.g a nickel plated binding post on a copper wire will also cause distortion. A copper oxide junction can even be a useful power rectifier if it grows thick enough. Cables, connectors, enclosures, etc. will exhibit small paramagnetic effects and create very low level harmonic distortion. There references for some common materials.
4) THD isn't the beginning and the end of distortion. Phase distortion is also important, and has a strong effect on the listeners perception of the sound (the psychoacoustics). A constant group delay is desirable, but may require additional complexity to achieve.
5) The distortion from whatever speaker is used and the room's acoustics overshadow the result of a competent audio amplifier design. Closing the feedback path beyond the transducer either by adding a sense coil to your speaker voice coil or a microphone both pose error signal quality and stability problems. Using a DSP to calibrate the feeedback transducer and then predistort the signal according to an adaptive algorithm evaluating realtime error signal samples could solve those problems and even overcome the room acoustics in at least a limited volume of the room. The design complexity is high, but some good algorithms for readily available hardware would be a considerable achievement.
Old 8th January 2004, 09:28 PM   #106
Bernhard's Avatar
Default Re: Lighter than air and faster than light...
Why do tubes sound good, though they are fully magnetic...
I know of all that sim problems, but I believe it is useful to test for warmer and colder.
If I have a circuit and get 120dB and after adding an error amp I get 150dB, that makes me believe it is the right direction.
Soon I will build it and we will see...
Old 8th January 2004, 09:30 PM   #107
Bernhard's Avatar
And hotter than hell... That reminds me on my tweeters*
*plazma
Old 8th January 2004, 09:33 PM   #108
Default Re: Re: Lighter than air and faster than light...
They are also not ultra low distortion...
JF
Old 8th January 2004, 11:28 PM   #109
traderbam's Avatar
I disagree with this. In my experience an amp design that is commonly called "competent" contains types of distortion that are extremely unnatural and thus more noticable/intrusive than those of "competent" speakers and certainly of room effects. After you've spent $5000 on your CD source your next highest priority is the amp.
Old 8th January 2004, 11:30 PM   #110
traderbam's Avatar
Another, lesser appreciated, reason that tube amps can sound very pleasing is the fact that tubes only come in NPN as it were.
Simple Killer Amp - Circuit analysis Eva Solid State 148 21st February 2006 12:32 PM
Copyright 1999-2017 diyAudio
