no mercy distortion killer circuit
Old 13th December 2003, 06:07 PM   #1
Bernhard is offline Bernhard  Germany
Bernhard's Avatar
Lightbulb no mercy distortion killer circuit
Hi ,
I got a circuit on the sim that:
- cancels* distortion of the output stage
- cancels* offset voltage of the output stage
- cancels* occuring clipping (kind of severe distortion) of the output stage
- probably even cancels* overshoot on square signals ( not tested yet )
- makes it possible to run the output stage with very little or no feedback if desired.
I think I will post schematic soon
Anybody interested to discuss this seriously ?
Or does anybody have an idea how I do that ?
*aproximately which means that on the sim, even under worst conditions as without feedback or while clipping, the output curve is absolutely matching the input curve
Old 13th December 2003, 06:36 PM   #2
Upupa Epops is offline Upupa Epops  Czech Republic
Go on !
Old 13th December 2003, 06:39 PM   #3
johnferrier is offline johnferrier  United States
johnferrier's Avatar
With a simple model/simulation, the concept of negative feedback cancels distortion. The hard part, of course, is cancelling distortion in reality. So how well does your simulation model reality?
And, of course, people will want to see more details: your schematic.
JF
Old 13th December 2003, 06:41 PM   #4
Pedja is offline Pedja  Serbia
The output curve while clipping matches the input curve?
Old 13th December 2003, 07:08 PM   #5
Bernhard's Avatar
Oh yes !!!
Old 13th December 2003, 07:30 PM   #6
Jan Dupont is offline Jan Dupont  Denmark
Jan Dupont's Avatar
Send a message via MSN to Jan Dupont
Lets hear more
Free Schematic and Service Manual downloads www.audio-circuit.dk, Spare time company (just for fun): www.dupont-audio.com
Old 13th December 2003, 07:37 PM   #7
tschrama is offline tschrama  Netherlands
Come on... show us...: can you post a schematic? This must be a very special topology...
Thijs
Old 13th December 2003, 07:38 PM   #8
Bernhard's Avatar
Default please be patient
Okay,
the red curve is the input , you do not see very much of it because it matches the output curve across the load which is green . The curve of the output stage is blue .
To see if the match is perfect, I made the amp a voltage follower, no voltage gain, only current.
The output stage is single ended classA and it is clipping and has got no feedback and has got terrible offset.
Still the output matches the input.
I did that to demonstrate what the circuit can do.
Of course the output stage can be with feedback and operated below clipping and with very little offset.
The rail voltages are 12V only because I just copied parts of the circuit from another of my amps.
Any circuit like this known to the public ?
I should call it "The mirror of the soul"
Old 13th December 2003, 08:00 PM   #9
Bernhard's Avatar
This is the circuit, it is a functional model.
Explanation follows.
Old 13th December 2003, 08:18 PM   #10
Bernhard's Avatar
The upper left side is the SE classA output stage. The op amp x3 could provide voltage gain if desired.
X5 is an inverting buffer.
R13 & R14 make the heart of the circuit.
The inverted input signal and the signal of the output stage cancel each other, left over is the distortion of the output stage, divided by factor 2.
The distortion is reamplified by the upper left side which is again a SE classA output stage. X4 provides voltage gain 2x.
The right stage compensates the errors of the left side.
Including distortion, offset, clipping, and hopefully even overshoot.
I know that the right side itself produces distortion.
But if the left side got some feedback so that it does good work, then the output of the right side will be only of a very very small amplitude, which means the new introduced distortion will be very very small too.
But nearly all of the left sides distortion will be canceled.
The circuit can be further improved, a differential amp and discrete parts instead of op amps could be used.
Because the output of the right side will be small except @ clipping, the right side rails can be as low as 7V or even less.
I hope this could be as good as the susy effect
Comments, critics and noble price welcome
no mercy distortion killer circuitHide this!Advertise here!
Simple Killer Amp - Circuit analysis Eva Solid State 148 21st February 2006 12:32 PM
Copyright ©1999-2017 diyAudio
