no mercy distortion killer circuit
Old 13th December 2003, 08:25 PM   #11
JensRasmussen is offline JensRasmussen  Denmark
JensRasmussen's Avatar
Send a message via ICQ to JensRasmussen Send a message via MSN to JensRasmussen
Default State space in idear
Nice work,
Is it based on a state space regulator?
How about some real life results?
\Jens
Old 13th December 2003, 08:29 PM   #12
Bernhard is offline Bernhard  Germany
Bernhard's Avatar
Default Re: State space in idear
Originally posted by JensRasmussen
Nice work,
\Jens
a please what
Old 13th December 2003, 08:40 PM   #13
millwood is offline millwood  United States
Account Disabled
Default Re: no mercy distortion killer circuit
Originally posted by Bernhard
Or does anybody have an idea how I do that ?
but does it make tea for me?
Old 13th December 2003, 08:48 PM   #14
Netlist is offline Netlist  Belgium
diyAudio Moderator Emeritus
Netlist's Avatar
Did you use current feedback opamps?
/Hugo
Old 13th December 2003, 08:57 PM   #15
Bernhard's Avatar
/Hugo
No, everything is NE5532 for simplicity.
Old 13th December 2003, 08:58 PM   #16
johnferrier is offline johnferrier  United States
johnferrier's Avatar
Bernhard,
I had thought that the cross-coupling topology would eliminate most distortion too.
See example on last page of the AD8610 datasheet:
http://www.analog.com/UploadedFiles/...D8610_20_c.pdf
This seems very similar to your circuit. There may be other cross-coupled diagrams that are closer to yours.
As I looked more carefully, I found that distortion at/caused by the input circuitry doesn't cancel because it looks like the signal. And at the outputs (across R8) the feedback isn't an identical mirror. On the left the feedback is from the output of X3, and on the right, the feedback is from the inverted output of X4. (This would all probably work okay with ideal components.) In my mind, these two aspects make it not work perfectly. Also, others have indicated this cross-coupled circuitry only cancels even order distortion.
Analog Devices and Texas Instruments actually make single ended to differential out chips that they claim lowers second harmonic distortion (no cancels).
JF
Old 13th December 2003, 09:14 PM   #17
Bernhard's Avatar
JF
John,
As I wrote, there is no feedback from the output stage to X3, just to simulate worst case conditions.
X3 needs his own feedback to be a voltage follower gain 1x.
Also this is not cross-coupled.
It is only from left side to right side, not vice versa. A one way ticket.
The function of the circuit is clearly defined, there is no question about how much coupling has to be.
R13/R14 are equal and gain of X4 is 2x gain of X3.
If the output stage is inside the feedback loop of X3, there is nothing left to worry about.
X5 could be a high end op amp like opa627 or it could be left out if X4 is a differential amp.
I also wrote this is a functional model and further improvements are possible.
Anyway it works perfect on the sim already.
Old 13th December 2003, 09:21 PM   #18
Upupa Epops is offline Upupa Epops  Czech Republic
This amp will have nonsymetrical slew rate and will be oscilate, 'cos gates of mosfets are driven from outputs of opamps without any serial resistor.
Old 13th December 2003, 09:21 PM   #19
But some of the distortion at/caused by the inputs of X3+ and X5- will look like signal.
JF
Old 13th December 2003, 09:24 PM   #20
Bernhard's Avatar
Yes, I forgot the gate resistors, sorry
no mercy distortion killer circuitHide this!Advertise here!
Simple Killer Amp - Circuit analysis Eva Solid State 148 21st February 2006 12:32 PM
Copyright ©1999-2017 diyAudio
