Kind of current mirror.
Old 30th August 2013, 04:53 PM   #1
Walkalone is offline Walkalone  Viet Nam
Default Kind of current mirror.
After i finished reading this thread:
Current Mirror Discussion
This is one of awesome thread in our forum. Manythings i can learn.
Well, here are 2 of best current mirror which i found from this thread. They're simple but have very good performance.
So, in ''Glen current mirror'' (left). R1, R2 are degen resistors of transistor. Ib (Q1) + Ib (Q2) + I (R3) = Ie (Q3).
Please, reply me: How much current through R3 is enough?
In Hawksford cascoded symmetrical Vas, what's the kind is better? I have seen Wilson current mirror in Mongrel circuits, Symasym...
Old 30th August 2013, 04:55 PM   #2
Sorry, i'm forget the pic.
Old 31st August 2013, 02:43 AM   #3
Anyone can help me?
In left, is Hfe of Q3 have influenced the result? Q3 need Vce > supply rail, if current through them too high, hard to find a accordant transistor (high Hfe and high Vce).
Old 31st August 2013, 08:39 AM   #4
JonSnell Electronic is offline JonSnell Electronic  United Kingdom
JonSnell Electronic's Avatar
It depends what the value of R3 is. Q1 and Q2 need to be balanced matched pair and require a nominal 0.6v to start with.
Support for Fender, Marshall and all Valve Equipment; Audio Innovations, Audiorama FU29, Quad and Leak. www.jonsnell.co.uk
Old 31st August 2013, 11:17 AM   #5
adjust R3 until Iin exactly equals Iout
Measure Iin & Iout at the "top" end using precision matched resistors of a value that gets adequate resolution at the currents you are using.
eg. if feeding an LTP, the LTP degen resistors could be 100r and passing 1.5mA each. A 199.9mVdc DMM would read 150.xmVdc across the degen resistors. You can get current match approaching 0.1% if careful.
Then replace the Vr for a fixed value of R3.
regards Andrew T.
Old 12th September 2013, 08:43 AM   #6
I' tested with a current mirror like here.
But i can't balancing current at 2 side of diff Vas to exactly. It's different a bit.
With improved Wilson current mirror, the current of two side seem very equal, to part per thousand of a Volt.
What's the best of CM for diff Vas?! Vas's used Hawksford cascode.
Old 12th September 2013, 08:47 AM   #7
Add a pic.
Resistors i'm used like pic, 100R x 2 for degen and 470R for base/compensator.
Kind of current mirror.Hide this!Advertise here!
Current Mirror stinius Solid State 16 3rd January 2010 06:33 PM
Current Mirror: The V-mirror rtarbell Solid State 1 19th November 2008 02:27 PM
no current mirror, current mirror, cascoded current mirror, bjt or jfet VAS? maxpou Solid State 31 17th June 2008 04:31 PM
Current mirror abzug Solid State 7 1st January 2008 07:03 PM
Copyright ©1999-2017 diyAudio
