LM3886 PCB design from Elektor
Tarun
If it's the LM3886 you want, and if you want to go the PCB route instead of the dead-bug route, then Elektor published a lovely little PCB for the LM3876/3886, in non-inv mode. This PCB does not support the LM3875, unfortunately, because that's not pin-compatible with the later chips. So, if you want that Elektor PCB design, let me know, and I can email you a PDF. That article was part of their Audio Collection.Peter Daniel said:Why don't you base your circuit more on what National is suggesting? Although it says LM1875, it doesn't change for LM3886 (except for mute).
Tarun
