Old 12th December 2003, 08:36 PM   #1
wrl is offline wrl  United States
Default Output transistors in halfer dh-200
Does anybody know if the output transistors are the same for the hafler dh-200 and the leach amp? Or if not would I be able to substitute those for the leach amp into the hafler.
I've had trouble finding the exact part # within the hafler documentation + I think the originals might be discontinued. Anyway, I'm planning on repopulating the hafler boards + had extra output transistors left over from my leach amp so it would be nice to swap those in as well.
Anybody know or have experience with this? (BrianGt maybe?)
Wes
Anything worth doing is worth doing right... and redoing to make it better... and again to fix it back the way it was.
Old 12th December 2003, 09:01 PM   #2
Netlist is offline Netlist  Belgium
Netlist's Avatar
Did you look here?
hafler dh-200 rebuild
I didn't read the whole thread but saw that Nelson was involved there.
Not a bad place to start IMO.
/Hugo
Old 12th December 2003, 09:20 PM   #3
I dont know if this is reliable but.....may have some use
http://users.otenet.gr/~athsam/HAFLER_DH_200.htm
Old 12th December 2003, 09:33 PM   #4
Netlist's Avatar
The link seems to be dead. Or is it me?
/Hugo
Old 12th December 2003, 10:11 PM   #5
Default Hafler
In this amp was used Hitachi 2SK 134 / 2SJ 49 ( two pairs in each channel ). If you can replace it, you may use BUZ 900 family.
Old 13th December 2003, 01:30 AM   #6
Default yep saw the thread
I looked into that, but Nelson seemed to be hinting at replacing it with a Class A type circuit. As I want to drive electrostatic speakers with this amp I don't paticularly want to do this. Just a simple repopulation with new parts (keeping the transformer + filter caps the same).
"If you can replace it, you may use BUZ 900 family." I'm not familiar with those.
Maybe motorala transistors... cause I already have like 20 of these lying around...
Thanks,
-Wes
Old 13th December 2003, 01:57 AM   #7
Tony is offline Tony  Philippines
Tony's Avatar
Send a message via Yahoo to Tony Send a message via Skype™ to Tony
hi wrl,
afaik, the dh220 has mosfet output trannies so you can not use them for a leach amp....if you want to use the chassis and other hardware, you can build a leach4.5 lo-tim amp on that chassis using the motorola part that you have....is this your intent?
cheers,
tony
Old 13th December 2003, 04:24 AM   #8
No, I already have a leach amp in a different chassis. I got a hafler off of e-bay that now doesn't work... stupid e-bay... anyway, it has good boards + psu so I was just going to repopulate. But I couldn't decifer from the manual what part #'s/brand the output transistors were.
Can I get these from on-semi?
-Wes
Old 13th December 2003, 04:33 AM   #9
You can be replaced with [ 2SK1530 in the place of 2SK135 ] and [ 2SJ201 in the place of 2SJ50 ].
Old 13th December 2003, 09:19 AM   #10
link works for me from my home and from work
Free halfer bridging board woody Swap Meet 2 3rd April 2008 09:26 PM
FS BG Ribbons Halfer dh200 parts woody Swap Meet 9 26th March 2008 02:54 PM
output transistors pezza89 Vendor's Bazaar 0 2nd November 2007 10:14 PM
Long output lead or long output transistors leads? which one to pick? chris ma Everything Else 3 6th June 2003 12:06 PM
Output Transistors weinstro Parts 1 9th May 2003 11:51 AM
Page generated in 0.12616 seconds (72.82% PHP - 27.18% MySQL) with 10 queries
