Yahama m60 - diyAudio
Old 16th August 2013, 01:24 AM   #1
comish4 is offline comish4  United States
Default Yahama m60
Working on Yahama m60 both left and right side are distorted this unit has all new transistors outputs,predrivers,drivers. It has new caps electros,almost new everything cant figure why output is distorted left side is a little worse than the right. Was wondering if the Jfet's could be bad? Any help would be appreciated Thanks in advance.
Old 18th August 2013, 09:47 AM   #2
Tarzan is offline Tarzan  Belgium
Tarzan's Avatar
You said that both channels are distorted.
They have both new transistors?
Wat comes to mind is the adjustments are not done correctly.
Here a table.
Good luck
Old 18th August 2013, 10:48 AM   #3
JonSnell Electronic's Avatar
Have you checked all of the resistors that have a triangle next to them? They are designed to fail and must, if failed, be replaced with exactly the same type and value. For safety.
The first thing I would do is check the outputs are sat at 0v and the drives are symmetrical. Then check the safety resistors.
Support for Fender, Marshall and all Valve Equipment; Audio Innovations, Audiorama FU29, Quad and Leak. www.jonsnell.co.uk
Old 18th August 2013, 06:57 PM   #4
Default Yahama m60
Thanks for the help i will check out the adj and the res. i have changed many resistors during the rebuild. Thanks again
yahama m60 comish4 Solid State 4 20th February 2013 08:54 PM
Yahama m60 amp comish4 Solid State 2 10th February 2013 01:39 AM
yahama A-S1000 advice nikkon Solid State 0 6th June 2011 07:11 AM
WTB: NHT M60 cabinets (or complete M60's) spurzheim Swap Meet 2 29th May 2011 06:53 PM
looking for Yahama YM3434 filter... moray james Parts 0 2nd November 2008 03:03 AM
Copyright 1999-2017 diyAudio
