Hello!
I hope I can receive some help in here. I have an old nad 214 with several problems. Well some of them are gone by now I think.. I bought it as not working ( stayed in protection). After reading about some of the usual reasons why the protection circuit could be on, I think I need some "new thinking" -fresh eyes on it
What I have done so far is:
-Replacing the output caps (C202-C205 + C901-C902)
-changed the output relay
-adjusted the dials on the left and right channels to 20mV (after 30 minutes)
-redone all solder joints
checked:
-C226
-D212
-R233
-C224
Okay... When I now turn the amp on it goes out of protection, and clicks the relay ON, and lights green in the powerlamp. BUT when I connect the speakers to the binding posts it clicks back in protection... funny... disconnecting the speakers again and it comes back on. I found out that when I switch to bridge mode, it goes in to protection as well I think that's where I need some help. Something in the output is wrong or out of specs.
I have heard that the IC 201 could fail as well, but I´m having a harder time finding a replacement to check with.
I hope some of you know something about the old NAD amps
Best regards
Martin
checked:
-C226
-D212
-R233
-C224
Best regards
Martin
Hello
I did something stupid! I was doing some measuring, and accidently dropped one pin of the multimeter out of my hand and down in the amp, where it killed a 1SS143 diode by shorting it to another component
I will get back if I can find a substitute.. maybe a 1N5614 would do it... Thanks so far.
Martin
Martin
A mere minor mishap
Leave it out of circuit if you haven't got anything to replace it with and power the amp up with a bulb tester to confirm no other damage is done. They only come into play under extremely high signal levels when they clamp the signal to the rails. All other times they do nothing so can be omitted for testing.
Okay, I´m back on track
I took the diodes out of both channels, and when i turn on the amp it clicks green... Nice!
It does look like the amp has a couple problems. When the speaker are connected to the left channel it stays in protection. When speaker are connected to the right channel MAJOR 50 Hz hum comes out! I will check all solder areas again.
Yes you are right! I have to check the value of all components. I would say it was a harsh bass tone.... more like a square tone than a sinus tone. I don´t have a scope, only my little multimeter.. But thanks for your time and help! I will get back when I find out more.
Martin
Martin
Well I was testing with a little JBL control 1... I might have bin fooled to think it was 50 Hz.. The speaker does not have much sinus response down there.... I don´t know.. it was only a second, but the signal was not clean. I will disconnect all the cabs and check there value, and then for shortcuts..
- NAD 214 in protection mode
