Amplifier troubles Plz Help
Old 11th December 2003, 05:04 AM   #1
ReverB is offline ReverB  United States
Exclamation Amplifier troubles Plz Help
Ok here is the problem. I am working with a kicker zr-240. When i bought it i tested it and it was in perfect working order. Now after being stored for 3 months i hooked it up and it is all screwed up. The amp did get banged around once but it wasnt too bad.
When i hook up the amp it pushes it seems like a combination of dc and ac current( i havent had a chance to test it because i recently moved and misplaced equipment). when i am not messing with the input sens. it seems to push out ac current and the speaker flutters at about i would say 10-30 Hz. when i am tweaking the amps input sens. it moves the speaker with a dc current in relation to the adjustments to the imput pot. Ya there is some REALLY weird stuff going on here.
Does anyone have any suggestions?
I was thinking that it could have somthing to do with the input ground. The amps output circ. is working because it is driving the speaker and the power light is coming on. This amp also has a removable crossover that i have switched out with one from a working amp.
I have no clue can someone please point me out in the right direction
Thank you,
Aaron
Amplifier troubles Plz HelpHide this!Advertise here!
Amp. troubles PLZ HELP!!!! ReverB Car Audio 5 1st November 2009 01:11 AM
SW troubles... PIA nunayafb Multi-Way 7 30th March 2006 12:04 PM
transformer troubles please help troublecomes Parts 4 31st December 2005 11:40 AM
ZV5 Startup Troubles keenlyside Pass Labs 0 13th June 2005 06:35 AM
amp troubles squid6 Tubes / Valves 5 8th July 2004 06:50 AM
