consultation - diyAudio
Old 2nd August 2013, 03:32 AM   #1
Default consultation
someone joined or tried this amp? I have doubts about the value of the inductor ...
Old 2nd August 2013, 04:13 AM   #2
Do you know what is that inductor used for...
Gajanan Phadte
Old 2nd August 2013, 07:31 AM   #3
That's a copy of the SILICON CHIP magazine 500W amplifier from around 1995. It's similar, apart from the cascoded VAS, to a big "Blameless" type design for amateur construction. Many were built here at the time, even in stereo format for some real muscle and a small competition was held by the mag. for the best build.
If you want Hi-fi performance though, the later Studio 350 design is cheaper and much better. Search threads for that here, if you wish. PCBs are still available.
regards
Old 3rd August 2013, 04:04 PM   #4
is that the inductor is used to protect the amplifier speakers, I think the issue of high frequencies, but my question was the value thereof, which are 21.5 turns of wire of a 1mm thick, but the overall diameter the coil is not specified ... that was my question, but I see the recommendation of "ian" and I think I'll build the design in December ... thanks and greetings to the forum ...
Old 3rd August 2013, 05:17 PM   #5
jaycee is offline jaycee  United Kingdom
The output inductor functions to isolate the amplifier from the effect of the speaker cable's capacitance. Its inductance value is not usually critical.
Old 3rd August 2013, 05:19 PM   #6
Also the schematic does describe the coil diameter, it specifies it should be wound on a P30/19 coil former. A little googling and you get this:
http://www.ferroxcube.com/prod/assets/p3019.pdf
Old 3rd August 2013, 05:20 PM   #7
thanks jaycee
River float speakers needs consultation torclausen Subwoofers 4 14th August 2012 10:46 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
