Old 10th December 2003, 10:36 PM   #1
punchpeanut's Avatar
Default Unbalanced Line Driver
I was just thinking about this earlier, is it this simple to make an unbalanced line driver? This should result in a 2X increase in voltage (say an input of 2V resulting in 4V) right? Do I need any other parts except for the cap to prevent the op amp from oscillating? What would be good op amps to use here, the standard NE5532, NE5534, Burr Browns, etc.?
Thanks.
Old 11th December 2003, 09:56 AM   #2
Probably you mean this
However you have to put at least 2uF
at the input and your output
will be inverted.
Federico
Line input transformer for unbalanced to balanced conversion okapi Chip Amps 23 12th January 2008 05:29 PM
Unbalanced to Balanced Line Level XFMR wrenchone Solid State 8 22nd October 2005 08:06 PM
Unbalanced Line Driver punchpeanut Solid State 7 12th December 2003 01:31 PM
unbalanced line stage almost completed Hanzwillem Pass Labs 15 24th October 2003 01:01 PM
Balanced line stage, quistion's + unbalanced lykkedk Pass Labs 4 19th December 2002 11:58 PM
Page generated in 0.07318 seconds (71.05% PHP - 28.95% MySQL) with 11 queries
