Old 10th December 2003, 10:33 PM   #1
punchpeanut's Avatar
Default Unbalanced Line Driver
I was just thinking about this earlier, is it this simple to make an unbalanced line driver? This should result in a 2X increase in voltage (say an input of 2V resulting in 4V) right? Do I need any other parts except for the cap to prevent the op amp from oscillating? What would be good op amps to use here, the standard NE5532, NE5534, Burr Browns, etc.?
Thanks.
Old 10th December 2003, 10:36 PM   #2
that won't work, as listed it isn't stable. a positive input voltage will create a positive output which is fedback. you need to attach to the negative terminal if you're going for an inverting amplifer.
if only it could be used for good, not evil...
Old 11th December 2003, 12:34 AM   #3
Thanks, I'm still trying to remember all my physics. It's been a while. So I should basically swap the connections on pins 2 and 3 right?
Old 11th December 2003, 04:34 AM   #4
azira is offline azira  United States
No, the non-inverting configuration is different than the inverting.
try this link:
http://www.leapfrogsw.com/noninverting.php3
your gain changes slightly, it's now 1+R1/R2 so you'll actually want to make your Resistors the same value.
Danny
Old 11th December 2003, 01:40 PM   #5
Thanks Azira, I was trying to make a non-inverting circuit, and the link you gave me helps me a lot. Thanks so much to everyone.
Old 11th December 2003, 04:48 PM   #6
Probably you mean this
However you have to put at least 2uF
at the input and your output
will be inverted.
Federico
Old 11th December 2003, 07:26 PM   #7
Didn't ANYONE else make this mistake when they were learning about opamps? He's just trying to make a non-inverting opamp.
When they first teach you about inverting opamps you "pretend" the inputs are at the same voltage and then just sum currents and *poof* you have gain.
So the first logical step is to reverse the inputs and it should be noninverting... I mean.... they tell you after all that the + is the noninverting and the - is the inverting...
I thought everyone does this in school.... ok atleast I did
actually it's funny how if you use the simplification assumptions, it doesn't matter which terminal is + or - it still works out to be an inverting.
Old 12th December 2003, 01:31 PM   #8
mskeete is offline mskeete  United Kingdom
You'll need a low value resistor (between 100 ohms - 1K) in series with the output to keep the opamp stable
Line input transformer for unbalanced to balanced conversion okapi Chip Amps 23 12th January 2008 05:29 PM
Unbalanced to Balanced Line Level XFMR wrenchone Solid State 8 22nd October 2005 08:06 PM
Unbalanced Line Driver punchpeanut Solid State 1 11th December 2003 09:56 AM
unbalanced line stage almost completed Hanzwillem Pass Labs 15 24th October 2003 01:01 PM
Balanced line stage, quistion's + unbalanced lykkedk Pass Labs 4 19th December 2002 11:58 PM
Copyright ©1999-2013 diyAudio
