amp picking up noise
Old 15th June 2001, 03:24 PM   #11
hugobross is offline hugobross  Europe
1) it could be possible that the noise is picked up at your connectors: in this case you can compare the "signal"-input with the ground of the connector (you can do this with a simple opamp)
2) I've had the same problem with a mixer: be sure that your power supply isn't placed in the neighbourhood of connectors or wires. If this is the case, you can also use a kind of COAX-cable to reduce the noise. It is always better to put the power supply in a grounded metal case.
3) If the noise still excist (after 1 and 2) and when it goes away after grounding the input, you can place a resistor (ex.: 10 Mohm) between the input and the ground.
When you use "jack-connectors" with a "build-in switch", you can ground the input automatically to the ground when you pull out the jack.
Best regards,
HugoBross
amp picking up noiseHide this!Advertise here!
Need help picking drivers for a 3 way Mike82 Multi-Way 9 2nd April 2009 02:39 AM
My amp is picking up noise ... Mambo Solid State 5 3rd February 2008 08:23 AM
Need help picking a mid.. PoorSound Multi-Way 44 4th September 2007 08:57 PM
Picking a tweeter, think I've got it... wigginjs Multi-Way 11 15th October 2004 12:59 AM
Why am I picking up so much noise on my scope? Bricolo Everything Else 54 8th June 2004 06:20 AM
Copyright ©1999-2017 diyAudio
