#11 |
The transistors sound like they are oriented properly; as for the pot, that sounds good too. You can check that the resistance across it (two of the legs are tied together on the board) is 2k-it must be close to this (or more) or the bias servo will not work. (Adjustments should be made only after getting the amp working on the 'real' supply)
#12 |
I suggest taking a bunch of voltage measurements, best would be to record voltages on all pins of all transistors. We should be able to figure it out from there. It sounds like a short or open circuit somewhere might be the problem.
#13 |
bugbite2k,
Are you actually using Rod's boards? I ask because I remember back in January you were trying to get the layout to do your own. It's important that we know whether you are using Rod's boards (which work) or your own (which may not work). Why do you think a picture of someone's finished amp will help you troubleshoot? |
#14 |
Yes I ordered 2 of them from Rod ..... and I ordered 300 watts sub board too..... That's why I been wasted alot of $ and didn't get it to work ..... I think if some 1 have a picture of the finished board so I could compared to my to see maybe I inserted some transistor wrong ..... but I'm really sure that I did follow Rod instructions
#15 |
hey guys I think I figured out the problem ..... on my R9 and R10, the value i put in it was wrong ..... instead of 2.7K I was mistaken and put in 3 ohm ...... any you you think that could cause my Qs to blow ?? well im going to the electronic shop to find the 2.7 K and sub it in ....... hope this would solve my problem ........ Thnx guys for all your helps
#16 |
I actually did the same thing once; 2 instead of 2k. It was easier to solve this problem, though, as the results were...rather spectacular.
I now test all of my resistors with a meter before inserting them. It's a nice reality check. |
#17 |
hey guys it's me again hehehe ,,, well I got it fixed up but still only I heard is trebly
any idea what I did wrong because I knew something wasn't right ...... how about the power hook up in the amp ? is it suppose to be where it said -35 and +35 is that where the power suppose to be hooked ?? and what about the Ground under +35 ??? isn't it for input ??? and the - out should also be ground too right ??? help me out hehehe guys, well I'm a newbie in electronic stuffs and this is my second years in hs also my second project in electronic class |
#18 |
Rod's diagrams are pretty clear. The power supply has three terminals, +35, -35, and GND. These connect to the same points on the amplifier. The input is applied between IN and GND. The speaker connects from OUT to GND.
#19 |
Did bugByte2k get it working?
DiyAudio |
| Maplin 100W mosfet amplifier - power supply problem | HBrunt | Solid State | 8 | 21st October 2011 01:04 AM |
| Project 100W MJ15003 MJ15004 | Risto80 | Car Audio | 2 | 26th June 2007 02:41 PM |
| He helps with amplifier " Lineal Power" Model 652IQ | diegodgo | Car Audio | 1 | 28th October 2006 08:05 PM |
| Need expert help on a project, ETI-488 100W | jacquesl | Solid State | 3 | 7th August 2005 02:22 PM |
| Page generated in 0.10036 seconds (78.36% PHP - 21.64% MySQL) with 11 queries |
