2DIFFET amplifier
2DIFFET amplifier
Old 25th July 2013, 05:36 AM   #1
OnAudio is offline OnAudio
OnAudio's Avatar
Default 2DIFFET amplifier
Click the image to open in full size.Click the image to open in full size.Click the image to open in full size.
Its about time we gave this one a thread
onaudio.herokuapp.com
Old 5th August 2013, 02:17 PM   #2
OnAudio's Avatar
Default PCB ideas welcome
Hi members am thinking of producing 100 free PCBs for this one. Any pcb ideas? The output devices will be TO247.
PCB ideas very much welcome.
kind regards,
Harrison.
Old 5th August 2013, 05:33 PM   #3
alex mm is offline alex mm  Romania
alex mm's Avatar
......C2 andC3 connected to ground ? should be, not across B , C ?
Old 5th August 2013, 11:18 PM   #4
jkuetemann is offline jkuetemann  Canada
jkuetemann's Avatar
Harrison seems to have a penchant for shunt compensation. Guess it works but is rather unkind to the VAS. I found on my SYMEF build I had to reconfigure the compensation from shunt to miller.
---Jason Kuetemann---
Power is only granted to those willing to lower themselves enough to pick it up.
Old 6th August 2013, 06:07 AM   #5
OnAudio's Avatar
Hi Alex, good to see you. Shunt or miller both are valid. Looking forward to your PCB ideas
Hi Jason, yes could have used the miller instead of shunt, but ended up preferring the shunt where possible.
kind regards,
Harrison.
Old 6th August 2013, 12:01 PM   #6
jkuetemann's Avatar
Don't get me wrong here, Harrison, I'm not saying shunt compensation is evil and wrong. I agree that both methods of compensation, shunt and miller, among others being discussed elsewhere are valid methods of compensation. I just think that shunt is more of a 'brute force' method and miller is more elegant a solution.
Old 6th August 2013, 01:30 PM   #7
student_sound is offline student_sound
student_sound's Avatar
Default Hi Mr Harrison !
SYM-DIFF I have an idea pcb like this
Old 8th August 2013, 07:34 AM   #8
Holgi is offline Holgi  Germany
Holgi's Avatar
I tried a variant allowing the Vbe multiplier tranny to be mounted on the heat sink
Pretty sure Alex can do a more sophisticated layout, anyway wanted to pay my 2ct.
BR,
Holgi
Old 8th August 2013, 09:43 AM   #9
Holgi's Avatar
Small Update to bottom layer (I missed one connection )
Old 8th August 2013, 03:40 PM   #10
OnAudio's Avatar
Hi student sound,
That is one very compact design . Some tracks need a bit of widening to carry the supply and output current . Thank you for joining the quest. Kindly give me more time during weekend to have a look at it just took a peek.
Hi Holgi,
Looking good. Could it be that you have followed SYMEF PCB Type1development . For 2DIFFET thermal runway should not be a problem. So only mosfets need to be on main heatsink. However if thermal/bias tracking is needed then the bias stage will have to be redesigned. Thank you for joining the quest. Kindly give me more time during weekend to have a look at it just took a peek.
kind regards,
Harrison.
2DIFFET amplifierHide this!Advertise here!
Questions about how to decrease the PASS A-40 amplifier into a class AB amplifier. novtango Pass Labs 4 14th February 2018 05:11 PM
Motional feedback amplifier based on Philips 40 wats amplifier 1970s sanbadgujar Solid State 14 13th October 2013 01:35 PM
converting PA amplifier into symetrical class A son of Zen amplifier muddasirwaheedmalik Pass Labs 5 16th October 2012 04:01 PM
An amplifier to take to University - A small low power integrated amplifier monty78pig Solid State 33 31st August 2012 06:00 AM
Wanted: DIY amplifier builder with experience. I need a 0.7 ohm stable amplifier Audiophilenoob Swap Meet 34 16th May 2005 11:58 PM
