Behringer EP2500 Bridge mode not working - diyAudio
Old 24th July 2013, 12:30 PM   #1
Default Behringer EP2500 Bridge mode not working
Ok, so I repaired this amp. CH2 was fried. Replaced o/p transistors and two Fets. Both channels now work great into a load. When I switch the dip switched to bridge mode, (yes I know how to bridge these amps with these switches), I get a very feint signal and the CH1 clip LED lights with only a very small volume setting. Waveform on scope looks pretty distorted.
Any ideas? I can post a schematic.
Old 24th July 2013, 05:32 PM   #2
Could you post the schematic? Could be a dud opamp used to invert one channel for bridge operation or something but without the circuit it's just a guess.
In the meantime, have you checked the DIP switches? Do all of them still make and break contact as they should?
Old 25th July 2013, 07:42 AM   #3
Hi I have checked the dip switches and ribbon cable. All check fine. I agree its something to do with the inversion cct somewhere. Strange thing is both channels work separately ok.
Old 28th July 2013, 10:36 AM   #4
Tarzan is offline Tarzan  Belgium
Tarzan's Avatar
Here the schematic.
It's in fact a .7z but I had to change it to .ZIP to get it through.
It can shed a light on the problem.
Old 28th July 2013, 10:44 AM   #5
stoN_Cold's Avatar
Do you connect speaker to Red output connectors?
Regards zeoN_Rider
Old 28th July 2013, 01:46 PM   #6
amptech is offline amptech  Scotland
Send a message via MSN to amptech
this was posted on different forum ...anz was ic6 solved
Wanted: Behringer Europower EP2500 Schematics steve_v Solid State 8 9th September 2012 04:38 PM
FS: Behringer EP2500 Subwoofer Amplifier mastershake Swap Meet 0 20th July 2011 12:52 AM
Behringer EP2500 improvement Modificationss AudioFi Solid State 1 8th April 2008 10:54 PM
Behringer ep2500 amp adlaic Solid State 18 31st August 2007 06:46 PM
Interest Check: Behringer EP2500 etc. Relax Swap Meet 0 11th August 2006 04:09 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd.
Copyright 1999-2016 diyAudio
