#41 |
Had had spare time to try again...
First I learned, fet's can be out of order while measuring ok for IDSS check. The defective device showed 900k of resistance between gate and source, new ones are beyond the capabilities of measuring. Still those defective device showed their once stated IDSS when testing. The offset between the gates of a pair was around 0.3V, with new ones 0.00V But, the current source (which I stuffed with new devices just to be on the safe side) now draws excessive power (around 36mA) There is no voltage drop over Rload, something still tricks me here... Rüdiger |
#42 |
Fred, you worry too much. Look at the construction of a 2SK146. Does this make sense to you? You will find that two 2SK147's are put together face to face. Guess what? One has to be upside down. Still they work, still they track. Why worry about it? The same goes for the 2SK170, and many other devices.
#43 | |
diyAudio Senior Member
Check it,)
Frank |
#44 |
diyAudio Retiree
"Fred, you worry too much. Look at the construction of a 2SK146. Does this make sense to you? You will find that two 2SK147's are put together face to face. Guess what? One has to be upside down.* Still they work, still they track. Why worry about it? The same goes for the 2SK170, and many other devices."
John I was trying to provoke the other JC a little. I did not think the Toshibas were asymmetrical as most jfets are which why I included the examples and the die diagram of the second source for the K147. I thought those were sufficient clues to indicate I was having a little fun with Mr. Carr..... Sorry you got caught in the crossfire of the pie fight. While you're here though, what should one do with that center pin on the K389 and J109 and when is actually all right to remove that tag on the mattress that reads Do Not Remove? Fred *Actuallly it not upside down but is rotated 180 degrees about the axis extending in the direction of the legs. You are right about the K146 indicates the two drain and two source legs are adjacent. |
#45 | |
I made a silly mistake I still have to figure out why the whole unit distorts lower frequencies while it is perfectly without noise and measures ok. Seems to be some weird interaction between fet-stage and output stage. Apart from that, i would really like to know, why a defective fet can pass through the correct amount of current? Rüdiger |
#46 |
... and, are source and drain of 2sk369 flipable (*ahem*) as well?
Rüdiger |
| FET's: LND150 and 2SK369 Substitutions ? | Jan Dupont | Parts | 13 | 21st November 2007 09:53 AM |
| 2sk170bl Where?? | GIPIONE | Solid State | 19 | 23rd October 2006 04:42 PM |
| Fs: 2sk170bl | Kilentra | Swap Meet | 14 | 22nd October 2004 06:54 PM |
| 2SK369 & Spice ? | CheffDeGaar | Parts | 23 | 12th February 2004 07:39 AM |
| What about 2sk369 in place of 2sk170 in MC phono | giolight | Pass Labs | 2 | 24th February 2003 10:35 AM |
| Page generated in 0.08968 seconds (73.35% PHP - 26.65% MySQL) with 11 queries |
