Need help adjusting Alto Macro 2400 - diyAudio
Old 10th July 2013, 09:11 PM   #1
pinyoro is offline pinyoro  United Kingdom
Default Need help adjusting Alto Macro 2400
I recently repaired a Alto Macro 2400 power amplifier. I had to replace the plus and minus HV switching transistors and output transistors on channel B. (All output transistors replaced). Amp is now operating but unfortunately the service procedure does not contain a setup procedure.
Service manual with schematics can be found here:
http://diagramas.diagramasde.com/aud...00,%202400.pdf
There is mention of the test procedure in the document but it is not in the document.
There are pots R23,R239 and R240 for adjustment.
May someone please advise how they would go about setting up this amp.
Thanks,
Mike
Old 10th July 2013, 09:42 PM   #2
JonSnell Electronic's Avatar
Send a message via Skype™ to JonSnell Electronic
If you haven't changed Q105/6 then the bias will still be correct. If you have, use a scope and set for no xover distortion with 8R load. Should be about 2mV across the output stage emmiter resistors.
Old 10th July 2013, 10:35 PM   #3
Thanks for your response. Q105/6 were not changed. If there is xover distortion, should I adjust R131? Does R139 and R140 control the voltage accross the emmitter resistors? Thanks.
Old 10th July 2013, 10:45 PM   #4
R131 adjusts the bias. the other pots set the mid point. Best left alone!
Old 11th July 2013, 04:34 PM   #5
LM3886 macro model ? rumors Chip Amps 7 7th December 2013 01:51 PM
Frontpanel express macro library Bas Horneman Software Tools 0 13th May 2013 10:05 AM
FS: Crown Macro Tech MA3600VZ Zero Cool Swap Meet 0 26th May 2009 12:36 AM
Crown Macro-Tech 600 problem pharaohamps Solid State 7 15th May 2008 01:02 PM
Spice Macro Model for floating supply opamp rtarbell Solid State 2 21st June 2006 04:14 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
