Old 9th December 2003, 06:14 PM   #21
Interested guys can find
the NINE PLUS schematic
at
http://www.geocities.com/fscarpa58/s.../nine_plus.pdf
bye
Federico
Old 10th December 2003, 03:39 PM   #22
or, in case of problems,
try download this
Federico
Old 11th December 2003, 01:43 AM   #23
Federico,
The Nine Plus schematic doesn't look like an original drawing. Is it a copy of an original, or perhaps taken from the amplifier itself? I'm just curious about where the schematic came from and how sure you are that it is accurate.
Thanks!
Old 11th December 2003, 08:49 AM   #24
Dear Joe, you are right
I get it from my blown unit.
Now I have the board on my table so,
if you have some questions, do not
hesitate.
Federico
Old 12th December 2003, 11:59 AM   #25
Default Sumo Nine
Hi Frederico,
Witch component is placed on the heatsink for temp. feedback
(Iq)?
Gert
Old 12th December 2003, 01:21 PM   #26
There is no need of temp. feedback
I think.
On the main heatsink we can obviously
see the 10 output device, while
the drivers Q11, Q14 are on a small
heatsink on the board. Q12, Q13
are on the board without heat sink
since they work only during peaks with load
<4 ohm.
Thermal stability is inerent to the adopted topology.
Look at the US patent 4229706.
However the output devices are not heavily biased,
say about 8W ( total 8x10x2= 160 W) at steady. That is a current of something less 200mA per device.
The amp become very hot, however, and there is a fan
to take count of that.
thank for the question Gert
Federico
Old 12th December 2003, 01:57 PM   #27
Thanks Frederico for the quick info.
It seems to me that this amp is a class a for small signals.I wonder how it sounds?
Gert
Old 12th December 2003, 05:40 PM   #28
The amp .works always in class A if the load is
no smaller than 4 ohms. When this happens
it switchs to A-B thanks to the aid of Q13
and Q12. However its class A is not
classic ( pure ) class A as you can read on
in the forum:
Amplifiers > Pass Labs > SE ClassA with low dissipation @ idle - is this it ?
(old thread)
message #26 and following.
the nine + is a great amp. I love it, I love they both
since i have two identical amp. in passive
vertical biamp
bye
Federico
Old 12th December 2003, 06:10 PM   #29
Account Disabled
I am interested in learning how this 9+ amp works. Anyone willing to explain to the less talented me?
Thanks in advance.
Old 13th December 2003, 03:50 AM   #30
Millwood, here is my attempt at a basic explanation.
The gain path itself is actually pretty straightforward. The dual opamp at left converts an unbalanced input signal to a balanced output signal and provides all the voltage gain for the circuit. Each phase of this balanced output signal is then buffered by a two-stage emitter follower, consisting of driver Q11/Q14 and its associated bank of 2SD555 output transistors, to drive the speaker load.
Overall feedback is taken from each output terminal back to the inverting input of the appropriate opamp. The 0.1 uF blocking caps in the feedback network result in 100% feedback at DC, so the dual opamp also acts to servo the output at 0VDC. So far, this is all pretty normal practice.
Now for the bias scheme. The amplifier contains four separate but interdependent current loops. Loop 1 goes from the positive terminal of the top 45V floating supply through the top bank of output transistors and back to the negative terminal of the bottom 45V floating power supply. Loop 2 flows from the positive terminal of the bottom 45V power supply through the bottom bank of output transistors and back to the negative terminal of the top 45V power supply.
Loops 3 and 4 go from the +55V front end power supply through driver transistors Q11 and Q14 respectively, flowing both through their respective emitter resistors R9/R30 and through the bases and emitter resistors of their respective output transistor banks, finally returning to the -20V power supply through their respective adjustable resistances R7-R14 and R29-R34.
The current in loops 3 and 4 controls the idle current in the output stage by defining both the base current in the output stage and the output stage bias voltage across driver emitter resistors R9/R30. The total current in each loop at no signal is held constant by Ohm's Law, since at no signal there is a constant 20V across R7-R14 and R29-R34. Regulation of these loop currents also prevents thermal runaway in the output stage by limiting the amount of base current available to fuel it.
The current-setting resistors in loops 3 and 4 pull down to a -20V supply, so they will continue to conduct current even when the output terminals swing negative to nearly the same level, again due to Ohm's Law. This means that output stage base current (and hence collector current) will continue to flow at full swing, albeit within limits and with the help of Q12 and Q13 as Federico has pointed out above. While this doesn't necessarily translate to linear operation, it at least avoids problems associated with switchoff in the output stage.
I don't know your background, but if you found the Bongiorno patent unclear and want to dig deeper into the techncal aspects of this circuit, I'd suggest doing a web search on Kirchoff's current law and the gain relationships (Ie=Ic+Ib, etc.) for bipolar transistors. Some understanding of these concepts may help shed more light on what is going on here.
SUMO Andromeda II bias or idle power? SQLGuy Solid State 6 23rd November 2011 04:55 PM
SUMO Polaris Class A/B Stereo Power AMP (New to the Board) thecavernut Solid State 12 15th November 2009 11:15 PM
Help! Save my Sumo &quot;The Power&quot; power amp. Chris Dian Solid State 15 11th January 2009 11:36 AM
Sumo The Power Schematic Alex helge Solid State 10 12th May 2005 11:37 PM
Page generated in 0.17103 seconds (62.59% PHP - 37.41% MySQL) with 11 queries
