Old 25th January 2006, 03:55 PM   #91
And here follows the 8 Ohm plot:
Old 25th January 2006, 03:56 PM   #92
And finally the plot for the no load condition:
Old 25th January 2006, 06:32 PM   #93
well Arcolette
there are to distinct uncorrekated point.
first the max amplitude of output signal on your sim
results to be about 32 Volts (hence 64W) while in my
sim it is about 36V (80W).
This is only due to the opamp device in two way
1) supply voltage : I have +- 21.5 since I measured
these values in both my amp (along with a float of 47 Volts)
2) opamp model
Then there is the switching problem.
It is not a problem of load. Yes I know that changing the load
you have a completely different behavior, the amp id designed so.
Rather, it is like you have a 300 Ohm resistor. I don't figure out why but try to set your resistor to 75 Ohm andlook at the results.
maybe this is only the result of different model.
As I said you, the only possible procedure is to set up correctly the amp based on the performance.
This is another methos more simple than the previous:
-set the load to 4 Ohm.
-set R38 very low in such a way the devices never cut off.
-go to the clipping condition (32 Volts or better if you succeded
in rise that value to 35-36V)
-start rising the value of r38. the central part of the current
will decrease. go on rising and stop when at the threshold of cut off.
now the amp is correctly set up.
Federico
Old 25th January 2006, 06:35 PM   #94
Does anybody know a replacement for the MPSu55 that's used in the Sumo Nine.?
sdman
try the NTE189 (or EGC189)
Federico
Old 27th January 2006, 07:47 PM   #95
Would be interesting to see the schematic of the Thorens
TEM3200. I see that they are using a driver xfm on the input side.
This way they get complete isloation.
Would like to see the translated version mentioned in post #76.
sdman
P.S. I used an on-line translator but it was with mixed results.
Sam
Old 27th January 2006, 11:14 PM   #96
aparatusonitus's Avatar
sdman
I guess that BD526/528/530 from Motorola would fit nicelly.
Best, Ivo
Non é mai abbastanza...
Old 31st January 2006, 08:57 AM   #97
sdman
BD238
SK3200
2SA818
from an equivalences search
hope this help
Federico
Old 1st February 2006, 07:12 AM   #98
djk is offline djk
djk's Avatar
http://www.onsemi.com/pub/Collateral/MPSW55-D.PDF
Old 8th April 2010, 10:47 AM   #99
tiefbassuebertr's Avatar
Originally Posted by Jan Dupont;278913 post #10
Some CROWN amps has the same...
Interesting. Please let me know some models - thank you.
here a circlotron circuit:
http://www.amplimos.it/images/CIRCLOTRON_50W.bmp
BTW - who knows the currently link from
http://www.audio-circuit.dk/images/s...ll-pwr-sch.pdf ??
Old 8th April 2010, 11:46 AM   #100
Jan Dupont's Avatar
Send a message via MSN to Jan Dupont
tief;
That was back in 2003
I don't recall the models, but you can do a search on their Legacy amp pages
Free Schematic and Service Manual downloads www.audio-circuit.dk, Company: www.dupont-audio.com, Joint venture: www.DupontMantra.com
SUMO Andromeda II bias or idle power? SQLGuy Solid State 6 23rd November 2011 04:55 PM
SUMO Polaris Class A/B Stereo Power AMP (New to the Board) thecavernut Solid State 12 15th November 2009 11:15 PM
Help! Save my Sumo "The Power" power amp. Chris Dian Solid State 15 11th January 2009 11:36 AM
Sumo The Power Schematic Alex helge Solid State 10 12th May 2005 11:37 PM
Page generated in 0.10890 seconds (78.95% PHP - 21.05% MySQL) with 11 queries
