Grounding in Power Amps
Old 8th December 2003, 02:20 PM   #1
richie00boy is offline richie00boy  United Kingdom
Did it Himself
richie00boy's Avatar
Default Grounding in Power Amps
In an amp I have 4 or 5 grounds:
i/p signal
o/p zobel
feedback
speaker
and possibly one for noisy stuff to be added later
I return the speaker to the star point at the junction of the main PSU caps. Should I also return the o/p zobel and feedback to this point individually, or can they join to a star point on the PCB which then is connected via wire to the PSU star point?
Can the i/p signal/PCB ref also use this on-board star point, or should it have its own connection?
Cheers
Old 8th December 2003, 03:56 PM   #2
audiofan is offline audiofan  Canada
You should find some example in this page about wiring a power amp http://users.ece.gatech.edu/~mleach/lowtim/part2.html
Grounding in Power AmpsHide this!Advertise here!
SMPS for diy audio amps and multi-channel diy amps (and their power supplies) tlparker Solid State 20 12th May 2015 12:23 PM
LM3875 kit grounding, optimal grounding for separate amps and psu? findog Chip Amps 9 16th May 2005 09:27 PM
Power grounding question falcott Chip Amps 0 21st September 2004 07:50 PM
grounding & power supply questions timsch75 Chip Amps 2 15th January 2004 05:04 PM
Grounding buzzing amps in general Gerontius Chip Amps 0 29th May 2003 09:56 AM
