problem with hk 730 - diyAudio
Old 4th July 2013, 02:54 AM   #1
Default problem with hk 730
changed the title of the post hoping to attract a bit more attention.
so i recently replaced the driver and output transistors on the 730 because i shorted them out a while back. anyway, the amp is working again.
there is another problem. when i power on the amp with either speakers or headphones connected there is a hissing noise for a couple seconds in the left channel then it ceases. there is then a hissing noise in the right channel then it ceases.
any ideas what could be causing this?
edit:
the hissing noise is a large temporary DC offset ~100mV reaching the speakers. any ideas what could cause that?
Old 4th July 2013, 10:23 PM   #2
sorry. here is the service manual.
https://docs.google.com/file/d/0B5bs...it?usp=sharing
Old 5th July 2013, 12:21 AM   #3
DreadPirate's Avatar
It could be normal. Mine also makes some strange noises as everything begins powering up. Takes about 3 seconds. If you look at the operators manual, you will see that they recommend disengaging the speakers prior to turning the unit on and then engaging them after a few seconds. I usually just disconnect them (via the speaker selector) every time I turn the unit off. My offset goes off the scale on turn on with the speakers engaged.
Old 5th July 2013, 01:08 AM   #4
scary.
repaired my hk 730 canadianicon25 Solid State 0 4th July 2013 02:00 AM
hk 730 canadianicon25 Solid State 3 6th June 2013 03:42 PM
HK AVR335 problem (no sound) mattau2000 Solid State 3 13th January 2009 07:26 PM
hk 670 problem(the vintage one, not the 2001 model) DragonMaster Solid State 7 8th April 2006 02:19 PM
HK 730 making noises... RockysDad Solid State 2 24th December 2005 01:45 AM
Copyright 1999-2017 diyAudio
