SKA GB150D now public domain... - Page 55 - diyAudio
Old 20th January 2014, 05:21 PM   #541
PauloPT is offline PauloPT  Portugal
Send a message via MSN to PauloPT
I have a soft start module. So, you're saying with the soft start the resistors aren't needed?
Kind Regards,
Paulo.
Old 20th January 2014, 05:49 PM   #542
still4given's Avatar
I thought Mike said the source resistor improved bias stability.
Old 20th January 2014, 06:44 PM   #543
The soft start controls the turn on surge. Not the bias.
The .15 resistors help stabilize the bias. They could be larger than .15, maybe as large as .47 but I haven't tried it.
Greg used 1 .15 per rail for simplicity. He likes to keep everything super simple if possible. I used a .15 per mosfet. More parts, yes. PITA to install, yes. But it works better.
Don't over think all this and look for problems that aren't there.
Mike
Old 20th January 2014, 09:42 PM   #544
Bigun is offline Bigun  Canada
Bigun's Avatar
The source resistors play multiple roles, including reducing turn-on surge current and helping with thermal stability of the bias. Increasing the value will have other effects (such as open loop gain of the FETs) so I'd just stick with 0R15. If you happen to have 0R22 in your junk box, for example, then I'd say you can use them without any worries.
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 21st January 2014, 02:32 AM   #545
Originally Posted by Ian Finch View Post
....Check the original types fitted......
I was talking about the Mosfet types there, since the resistors were added when these were changed and the PCBs amended. There was a brief explanation on the SKA open forum at the time when I assumed the replacement type had lower Rds but no, I don't have an original to compare, though gallery pics on the forum support this since only two 10R/1W resistors are of any size in there. So, that's why the suggestion to compare the Mosfet types fitted in the modified and original designs, as is AndrewT's.
Greg's comment at the time of release when Toshiba 2SK1530/J201 were suggested as options, was no - the design requires a relatively high Vgs of 3.5V to work properly. AFAIK, nothing's changed since then.
Ian
Old 21st January 2014, 09:13 AM   #546
A single shared Source resistor has an effect equivalent to two separate double value Source resistors.
i.e. two 0r3 gives the same bias stabilising effect as a single 0r15
0r3 for a 2pair FET output stage is quite high for Source Resistors.
That is a very big change in philosophy for a stage that was supposedly bias stable by just selecting Vgs to within 10mVgs.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 21st January 2014, 04:00 PM   #547
Bigun's Avatar
In my TGM7 I use 0R15 without any issues. I also use a soft-start module.
Old 22nd January 2014, 07:31 AM   #548
borys is offline borys  Ireland
borys's Avatar
I got some spare time for basic measurements of my v1 board (I will have to improve it a bit). Now is time for listening some tunes. The bias is way to much overcompensated so i will try to add another diode to diode connected transistor and increase resistor for CCS. In my case I am using bd139/140-16 for bias sensors (maybe different transistors will be beter but I will try diode anyway). There is no hum noises at all, amp is rock dead with input shorted.
Now first impresions, the bass is really ok, the hights I like but they are different to the other amps I had. Really nice amp.
The measures show falling down harmonics spectrum - maybe this is the key to the good sound --> I do not know. I had to set bias at minimum 150mA to get really good sound out of it.
Big Thanks for Greg --> good job.
thx for bigun for support and answering my stupid questions :P
Old 23rd January 2014, 07:21 PM   #549
borys's Avatar
The v2 board If someone needs it.
Old 24th January 2014, 02:41 AM   #550
Bigun's Avatar
Originally Posted by borys View Post
I got some spare time for basic measurements ....
Very nice to see measurements - you must have some nice equipment. What is happening as the frequency goes up - looks like D3 is decreasing between 1k and 10k ??? - I assume "D3" is the third harmonic. Anyhow, even though I don't understand all these things I do like the distortion profile, it looks very nice being dominated by D2 (2nd harmonic).
You are right about the listening impressions, I also found the highs are different to other amps. I didn't get a chance to listen enough yet though.
FS: SKA GB150D modules and power supply muzza Swap Meet 1 28th November 2011 09:14 AM
Any Zu Audio type designs in the public domain? audiothings Multi-Way 5 24th November 2010 04:05 PM
M-1 amplifier kit - full documentation in public domain now audiovista Tubes / Valves 1 6th January 2007 04:21 PM
BZLS and SKA GB150D hcbonfim Solid State 9 5th November 2006 09:16 AM
Copyright 1999-2017 diyAudio
