Best low-noise low-distortion buffer? - diyAudio
Old 8th December 2003, 09:03 AM   #1
borges is offline borges  Norway
Default Best low-noise low-distortion buffer?
At the output of a CD player project I need to buffer (and possibly multiply by two) the output of a passive filter. There's plenty of power supply voltage (+-18V).
The buffer should be fit for driving both phono and XLR inputs of preamps.
I don't care too much if the buffer introduces an offset voltage as long as it doesn't change too much with temperature and across channels.
I have been thinking about opamps as unity-gain buffers and maybe in a gain of +2. Now I wonder if I can get better audio performance with a source follower. I have been reading Douglas Self's page on CPF source followers (http://www.dself.dsl.pipex.com/ampins/discrete/cfp.htm).
What I want to ask you is if this is my best option. Or will a good opamp like for instance the OPA2134 offer better sound quality?
Greetings,
BÝrge
Old 8th December 2003, 08:51 PM   #2
PRR is offline PRR  United States
PRR's Avatar
The better chip-op-amps are very good. I don't see how the CPF is any better. It is more work, has substantial offset, can't give gain as shown, and is very prone to self-oscillation (which can be a royal pain to find and fix).
Old 9th December 2003, 02:41 AM   #3
Banned
I do not like op-amps as unity gain buffers. JFET followers sound good, although they will not drive 600 ohms.
CFP are ok, but I have never needed one as a buffer for a CDP. They may sound a bit too constricted, when compared to a follower.
Diamond buffers would work fine, if you need current drive.
If your D/A chip is a R-2R type, just change the load resistor to get that 6 dB gain.
Jocko
Old 9th December 2003, 08:51 AM   #4
PAM is offline PAM  Netherlands
PAM's Avatar
Default easy buffer
An easy way to make a good buffer is the BUF 634.
WADIA used them in there CD players.
I compared a Musical Fidality X10D (tubes) with an stand alone batterie powered BUF 634. The BUF 634 wins clearly at 1/10 th of the costs.
The BUF 634 is cheap, fast and powerfull.
Old 9th December 2003, 09:01 AM   #5
sobazz is offline sobazz  Denmark
sobazz's Avatar
In the high-end headphone amp project PPA they chose Intersils HA3-5002 over BUF634.... And Intersils is cheaper.
Old 9th December 2003, 09:17 AM   #6
Default Need good buffer schematic
I wonder if anybody can help me out with a buffer circuit design.
I'm currently building an APOX preamp and I would like to have a couple of tape outputs. Just tapping into the input selection bus doesn't seem to me a good idea, bacause I'd probably end up overloading the source.
Can anybody point me to a very good buffer schematic? Possibly I'd like a tested design, so that I don't have to experiment too much...
It seems to me that it should have a 1:1 gain. FYI, the signal bus is balanced.
Old 9th December 2003, 09:19 AM   #7
Thans folks
Jocko, what is a diamond buffer?
My dac is a current output type which I planned to filter passively and then buffer.
I saw a previous thread on the use of CPF followers(Help a nOOb out with an emitter-follower...) which seemed very interesting. Do you think this circuit with a constant current generator is capable of pulling 600Ohms?
Another issue is that the signal current those 600Ohms will be downscaled by beta and be seen at the base. However, I don't mind (small) constant base currents.
So the question remains: Do you have any experience with FET CPFs?
What I plan to do is to make a test board with an opamp socket and a couple followers that I can jump in and out. Now I'm just trying to figure out which followers are worthy of occupying FR4 real estate
BÝrge
Old 9th December 2003, 12:40 PM   #8
johnferrier's Avatar
Default Re: Need good buffer schematic
http://www.elecdesign.com/Globals/Pl...tent/2800.html
JF
buffer noise Sheldon Chip Amps 24 27th July 2010 01:10 AM
Lowering Buffer Opamp Distortion mrfeedback Solid State 9 8th January 2009 04:16 PM
Simple Low Distortion JFET Buffer wrenchone Solid State 21 29th January 2007 08:16 PM
testing distortion/noise on a X'd amp? rif Pass Labs 1 18th August 2004 06:23 PM
Copyright ©1999-2017 diyAudio
